1987 iroc 5.7 TPI no spark
Car: 1987 iroc
Engine: 5.7
Transmission: B&M 700 r4
Hello to all long time reader 1st time poster
I have a 1987 iroc with 5.7 l98 all arizona speed and marine TPI setup i put on back in the early 90s have had car since 1991 large tube runners ported plenum ported heads ZZ3 cam and so on . . i haven't driven car much over the last 10 years or so i drag race a motorcycle and it takes all my time so car sits in garage . Over the last few years car has been getting harder and harder to start. i crank and crank and it will eventually start running on about 4 or 5 cylinders then starts hitting on all of them after about a minute it also has the cold start injector . About 2 weeks ago i tried starting it and it started up after cranking it for a long time then just slowly came to life the longer it ran and ran fine after that . But i let it sit overnight and tried to start it the next day wouldnt start . Went to start it over the weekend now nothing i dont even hear the fuel pump prime when i turn the key on but i checked it and it has fuel pressure i guess after i crank it a little bit the pump must come on .
I checked for spark and there was none so i disconnected the MSD ignition and coil and put the stock coil back on still no spark so then replaced the module in the distributor and still no spark . Then i went to check for codes i am not getting anything the check engine light does not even come on when i turn on the key .The bulb is good all fuses are good all the gauges come on but no check engine light . I am a little stumped to say the least it also has new MAF sensor i put on about 6 months ago . could my ECM have taken a crap ????? I also checked the line fuse coming from the battery that is good. Also installed new 24lb injectors about 3 years ago ran real good after that
I would greatly appreciate any info on where to start checking for this issue
Thanks in advance
Steve
Thanks in advance
Steve
Re: 1987 iroc 5.7 TPI no spark
No where do you mention that you checked the battery's state of charge. That's the first thing I would check.
You ride bikes so maybe you know this already, but a battery maintainer is a good investment.
You do pour in fuel stabilizer into the gas tank and let the engine run to distribute it, yes?
Car: 1987 iroc
Engine: 5.7
Thanks for the reply yes the battery is on a battery tender and is in a full state of charge as for the fuel i mix a gallon or two of sunoco 110 octane or go up the street to local small airport and get 104 octane AV fuel which is a great stabilizer .
Car: 1987 iroc
Engine: 5.7
Ok i just ordered a new computer for the car thats the only thing i can think of to do from here after checking the entire wiring harness and found nothing . also have power everywhere its supposed to be . guess not many people have encountered this problem
I have a 89 iroc with 5.7 all stock with 71,000 miles .I'm having the same problem! No spark. I have replaced ecm,new prom chip, esc, complete dist, new coil, plug wires, relays, alt., starter and battery. When cranking engine it gets a very weak spark. Let me know if you figure out your problem. Thanks Heath
