White/blue smoke at start up- what could be the cause??
Car: 1988 Camaro IROC-Z convertible
I've got a 1988 IROC convertible with the 305 TPI, whenever I start the car up hot or cold I get a large amount of white/blue smoke...what is/are the possible cause(s) of this. Thanks for any help!
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: White/blue smoke at start up- what could be the cause??
Valve seals need replacing.
Car: 1986 Iroc Z28
+ another 1 for valve seals! Mine does same thing, just havent got around to replacing. Sounds like Abubaca is dead on when he says they all do it.
I've noticed it seems to happen sooner on 305's than 350's though.
Car: 88GTA
Engine: 5.7TPI
+ another!! JOIN THE CROWD!!!! GM replaced mine at 40k under warrenty. It's time once again!!
Car: 88GTA
Engine: 5.7TPI
Arnold, on a warm start-up, you MAY have injectors leaking...hot soaks...fuel leaking into cylinders. I guess you could check your pressure at the rail before you start it up warm and see if it has pressure at the rail. Just some idears.
But yeah, with your seals sitting so long, who knows.
Mine was smoking on warm start ups and the first "take off" from a stoplight if it idled there for an extended time.
Surprisingly valve seals and a fresh oil change(not sure when the last time it was done) cured nearly all of my issues!
I used the Fel-Pro intake ones on all valves and it worked out great!
Bob, I think you mentioned that possibility to me when we spoke a while back. I'm looking to remedy this problem this Summer so I will have them checked.
Thanks bud!
Car: 88GTA
Engine: 5.7TPI
Arnold, yeah, I think I remember that...sometimes sett'n in!
NufNuff, did you use the PITA little "O" rings with them too, or just the the intake ones alone?
[NC] 305 tpi LB9 for sale
86ZRESTO
05-21-2018 08:33 AM
88 vert guy
04-04-2016 11:01 AM
