IAC 1987 5.7 iroc
IAC 1987 5.7 iroc
Hello All,
I have a surging idle and tried to reset the IAC. Followed the procedures outlined but after installing the paper clip and unplugging the IAC connector then removing the paperclip the engine will not start without the pressing and holding the accelerator pedal.What's up with that?
Thanks for any help/input,
Robin Bailer
Destin,Fl
Robin Bailer
Destin,Fl
Car: 88GTA
Engine: 5.7TPI
Re: IAC 1987 5.7 iroc
You probebly will have to turn the idle stop screw in a little so it will start. Turn it in quite as bit to get it to start, then back it out till you get down to the target of 4-500 rpm. It will barely run at that point.
GL
-Bob
GL
-Bob
