FNG with another question
as a few of the members on here have replied to my other thread about the cold start issue, well i have another problem. Great... let me start off with some details so you guys aren't wild guessing about what i've got here.
86 tpi camaro with a jasper stage 1 350
jet stage 2 305 chip
accel 24lb injectors
edelbrock shorty headers with the y pipe
stock induction system besides what is listed above
accel supercoil
othertwise pretty much stock engine wise
so the issues is when i start the car sometimes it surges BAD. then throws a code but doesn't store it. weird right? well after all that is over it loads up and has horrible throttle response until it warms up after a while. so far i have replaced the fuel pump, maf, and burnoff relays and replaced the iac. the fuel filter was just replaced about a month ago if that helps. thanks guys!
accel supercoil
Re: FNG with another question
accel supercoil
accel supercoil
- First start after sitting overnight?
- All the time even at or near operating temperature?
Car: 1991 RS
Engine: 5.0
I would have to agree with MoJoe. If it's a mail order chip it's not doing you any favors. You need to have it custom tuned on a dyno, or at the very least find a 350 chip. I would also check the basics like timing, fuel pressure, tps maybe.
thanks for all the info guys i'll check all of that a report back!
my dad seems to think its the distributor... how he came to that conclusion we may never know. the reason it has the 305 chip in it was because no one made a 350 chip at the time (roughly around 2002). so i will be looking for atleast a 350 chip
so we hit up tpiparts.net for one of their chips. got it in today and it solved the surging issue on the cold start but now there's a stumble on acceleration.
Mr70Monte
01-14-2020 04:19 PM
