EGR Part ID
EGR Part ID
So my car was smoking pretty bad the other day and I noticed that the EGR Valve has a broken/cracked connector. I took the EGR valve off and went to Advanced Auto but they couldn't find any part that looked remotely close to what I have. Anyone know the part number is...here are a few pics . Thanks in Advance!
Re: EGR Part ID
The Exhaust Gas Recirculation (EGR) valve is cast iron and steel and is mounted under the intake plenum. That is an heat bypass valve, and there should be coolant in those hoses. If the cooling system was not intentionally drained for the photo, it was drained inadvertently when the valve body broke. DO NOT start the engine until that it repaired and the cooling system is refilled.
If your local parts stores cannot identify a replacement, you might want to suggest a source for them.
https://www.amazon.com/ACDelco-15-53.../dp/B000C9GUJ4
http://www.oreillyauto.com/site/c/de...2708&ppt=C0331
Re: EGR Part ID
Thanks, yes I meant to update it the thread. My local store had the heater bypass valve, I picked it up along with the rubber hose. I will replace it all tomorrow and refill the coolant. Thanks for the help!
david auster
Aftermarket Product Review
04-07-2001 10:09 PM
Hecubus
04-05-2001 08:45 AM
86Trans Am
11-10-2000 08:11 AM
