Fuel Injection swap to carb
Hey guys, I have a 1987 Pontiac GTA with a L98 TPI. I plan to swap the TPI for an aluminum intake and Holley carb.. My question is can anyone tell me what guys normally do with the injector wiring harness after the swap. I'm writing this and haven't even checked to see if I can simply just disconnect the harness from the computer yet. Also, is there anything I should know to do after the swap. I know I 'll have to engineer a linkage and the vacuum differently.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Fuel Injection swap to carb
i usually keep the wiring intact, i get rid of the carburetors.
