Vapor canister vacuum
Car: 86 Trans Am
Engine: 305 LB9
Quick question,
I've been getting terrible mpg in town. Approx. 12 mpg. Used to get 17 to 20 because of how easy I drive. Changed oil the other day and spark plugs were done a few months back. So I went snooping and I found the round portion on top of the vapor canister had its vacuum hose come loose and off. So I bought a new more snug fitting one at Autozone. Would that have had an adverse affect on my mpg? Or should I continue looking else where
Re: Vapor canister vacuum
In general, yes.
If you have a vacuum leak, this creates a lean mixture condition which the O2 sensor will report to the ECM. The ECM in turn will try to richen the mixture by decreasing the injector dwell time (the time the injector is off). Net result, your engine is now running overly rich.
Car: 86 Trans Am
Engine: 305 LB9
In general, yes.
