Running lean after battery change.
Old 01-02-2017, 09:17 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Hey guys. Recently my tpi has started running rough at idle and around 1200 rpm. It happens during a battery change. If I remove the ground and reset the computer sometimes it runs perfect for ever. Until I accidentally leave a light or something on and the battery drains and I recharge it and put it back on. And it requires me to mess with it some more. Is this a computer issue? I replaced all known vacuum leaks
Old 01-03-2017, 12:39 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Running lean after battery change.
The ecm has some learning /correction it will do. Disconnecting the battery erases sam @"stay alive memory ".
Old 01-03-2017, 01:18 PM
BOTTLEDZ28's Avatar
Transmission: A4
How do you know its running lean? Like mentioned above, the ECM will lose its saved memory once the battery is removed or disconnected but the car should have no problem starting backup and running fine.
