Sportsman II's with an LT4 Hot cam
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I just want to make sure the springs will take the cam if i buy the heads already assembled. If not then i will have to buy the kit and then assemble the heads myself.
i'm going with the same setup with the sportsman 2's and the lt4 for my 355 build. they do come with two sets of springs but i believe the smaller set will work great. the cam's lift is either .492 or .495 and the smaller springs i believe are good to .550 or .600. thanks
1988iroc350tpi
08-14-2015 07:52 PM
