T-56 Shifter Ball with offset button
Old 04-03-2003, 01:19 PM
Mark W. Winning's Avatar
Has any one seen the ad for a new Hurst or Mr Gasket shifter ball that has the button to the side and not on top like normal. If so, could you please post what mag you found it in. I cannot find it again.
TIA
Mark
Old 04-06-2003, 08:58 AM
ttt
Old 04-06-2003, 02:10 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
If this button is for the reverse lockout solenoid forget the button. Just wire it up to the stop light switch, so whenever you hit the brakes it will allow you to shift into reverse. Just remove the drivers side sill plate and pop the plastic harness protector appart. In that group of wires there will be a light blue one, which is connected to the stop light switch.
Old 04-07-2003, 07:34 AM
Nope, I am going to hit it with a 100 shot. My reverse lockout is not connected and it doesn't case me any problems.
Mark
Old 05-12-2010, 07:37 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: T-56 Shifter Ball with offset button
here ya go http://www.hurst-shifters.com/hurst-...T-****-6-SPEED
Old 05-12-2010, 09:07 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Something tells me that in the last 7 years, the OP has made up his mind already
Old 05-12-2010, 10:54 AM
tom86iroc's Avatar
Car: 1986 iroc
WOW LOL never even looked at the thread date lol
BrianChevy
Wheels and Tires
10-13-2015 12:33 PM
mcfastestZ28
10-05-2015 07:12 AM
sjorgens
10-01-2015 07:54 PM
Quick Reply: T-56 Shifter Ball with offset button
