How bad is if for the tranny to be overfilled?
Old 11-07-2003, 08:29 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Like a complete moron I didn't check my trans fluid since I bought the car (about 2.5k ago). Anyway I checked it a few days ago and its pretty high, probably 1-2 quarts. My problem is i'm in college right now so there isn't really anything I can do about it besides pay a shop way to much to change and flush the fluid for me. I was planning flushing it and going to synthetic when I went home for thanksgiving break it will probably be another 300-400 miles. How bad is this?
I checked every other fluid in the damn thing, once or twice a week, for some reason it just occured to me that I haddn't even looked at the tranny fluid since I got it
Old 11-07-2003, 08:39 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Buy a wide and long tupper wear box, then jack the car up and take out the pan. Drain, put pan back in with new gasket/filter. Then fill.
Do it before you kill the tranny from overheating. Overheating the tranny is a VERY bad thing. You could also blow the pump.
Old 11-07-2003, 10:13 PM
0cP
0cP's Avatar
You can go to the hardware store and get a really long 1/4" tube stick it down the filler tube and suck away. If you can get under the car then pop out the filler tube and then u can use a real short peice of tube.
Old 11-07-2003, 10:38 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Yeah, the thing is I don't want to change it now because its going to be changed to synthetic in about 400 miles, I don't have a jack, stands, ramps or anything with me, although its a great excuse to buy a nice floorjack and stands if a cop drive by and I have my car up in the parking garge they might be dick and make me put it down and have it towed to a shop to finish. The tube sounds like a good idea though.
Old 11-08-2003, 09:25 AM
25THRSS's Avatar
just syphon it out for now.
Old 11-08-2003, 10:59 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Make sure your checking the fluid while the car is running, in case you didn't know. Fluid level drops dramaticly when the car is started.
Old 11-08-2003, 11:53 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Yeah, thanks I think Ill just go to the hardware store today and pick up some rubber hose.
Yeah I checked it while running, a mechanic once told me though to change gears a couple times before checking it like PNRPD, i tried both, both times it came up way high.
GouldyGTR
09-07-2015 09:05 PM
Stryker412
09-07-2015 09:11 AM
apie2546
09-05-2015 07:40 PM
IROCZ1989
09-04-2015 11:54 AM
Formula_88AE
09-03-2015 01:47 PM
Quick Reply: How bad is if for the tranny to be overfilled?
