Plastic tailshaft plug to keep fluid in trans on engine pull - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 02-06-2004, 05:12 PM   #1
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Does anyone know where I can order those little plastic plugs to plug the driveshaft splines/seal when I have the driveshaft out? 700R4 if this makes a difference. I'm going to be pulling my engine/trans this spring and don't want trans fluid going everywhere if I can help it. It's much easier to drain things outside of the car rather than fumbling around while the car is on stands... Searched with no results.
bnoon is offline vBGarage Page   Reply With Quote
Old 02-06-2004, 05:14 PM   #2
Car: 4
Engine: 6
Transmission: 5
I just use an old drive shaft yoke.... you could probably pick up a fornicated one at any shop that works on drive shafts & U-joints, that would work fine as a b.... errrr, tail plug
RB83L69 is offline vBGarage Page   Reply With Quote
Old 02-06-2004, 05:15 PM   #3
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I saw some at the local Kragen parts store the other day. Personally, when I put in the new driveshaft, it came with a new yoke so I kept the one off the old driveshaft just for that purpose. It will get used next weekend when I swap trannies....
Captain C is offline vBGarage Page   Reply With Quote
Old 02-06-2004, 05:17 PM   #4
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, just use an old yoke and weld the weep hole shut. Then duct tape it to the tailshaft so it doesn't slide out and you're good to go.
TKOPerformance is offline vBGarage Page   Reply With Quote
Old 02-06-2004, 05:30 PM   #5
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
oh. thats a good idea. i wish i had thought of that when i did mine. it was messy...
manchesterbeast is offline vBGarage Page   Reply With Quote
Old 02-06-2004, 05:47 PM   #6
Thanks for the ideas guys. I was really looking for the "spend a few bucks and have it show up on my door step" way though. No driveshaft shops on my side of town. They're all painstakingly out of my way. Anyone know if the GM transmissions share tailshaft hole size? Seems all of the little plastic plugs you need to know the size of the hole... 1.5" is all I've found so far for GM trans' online.
Old 02-06-2004, 07:52 PM   #7
You can also take a 1 liter soda bottle and cut the end off of it and then slide it over the tailshaft as far as it will go. Then duct tape the heck out of it. I've used this before in a pinch and to make trail repairs, and it's kind of el cheapo, but it works.
Old 02-07-2004, 10:29 AM   #8
Car: 1985 IROC-Z
Another option is to drop the pan and drain the fluid..... Not the way I want to do it!!!!!!
Several GM transmissions use the same yoke. The Th-350, 700-R4, Th-200 & 200-4R, and I think all the stick shift cars used the same yoke. I do know the Th-400 uses a larger yoke....
Old 02-07-2004, 03:02 PM   #9
That's some info I can use, thanks!
Old 02-07-2004, 05:32 PM   #10
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Quote:
That's not as ghetto as what i did one time. I just duct taped lot's of socks over the tailshaft one time when i was in a rush to swap trans. You can imagine how long that lasted till the tranny fluid soaked through the socks
acescarrsRS is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
List of 71 original GM 3rd Gen Part Numbers!! 1992 Trans Am History / Originality 16 04-05-2016 11:20 PM
Whats she worth? Exxon Limited Camaros Wanted 22 12-21-2015 11:36 PM
Code 12 Distributor not sending to ECM bradleydeanuhl DFI and ECM 4 08-12-2015 12:48 PM
92 3.1 v6 Automatic trans Oil & filter change? maroe624 Transmissions and Drivetrain 2 08-08-2015 11:35 AM
88 iroc auto trans Leggman1 Transmissions and Drivetrain 3 08-06-2015 05:15 AM
Go Back   Third Generation F-Body Message Boards >
Tags
350, 700r4, c4, engine, plastic, plug, plugs, shft, size, t56, tail, tailshaft, th400, transmission, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
