Manual Transmission Mount
Old 03-24-2004, 08:50 AM
RandogLeader's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 5-Speed Manual
Greetings! I have a 1989 Camaro RS 2.8L MPFI 5-Speed manual tranny. The transmission mount is broken and the replacement is ridiculously overpriced at $300. Wondered if anyone has had to do this. I wouldn't mind replacing the crossmember in leu of using a cheaper tranny mount. Any ideas or suggestions?
Here's a pic of the mount that is on there now.
Old 03-24-2004, 10:01 AM
ede
ede's Avatar
jegs shows ES pn 1108 to be a universal fit application, or gm didn't make any changes over the years. cost is 20 dollars.
Old 03-24-2004, 11:52 AM
MdFormula350's Avatar
http://www.spohn.net/product.cfm?productid=1349
i would get that mount, and then just find a thirdgen crossmember like this.
that should work i dont think it matters if u have a v6 engine and tranny or not.
thats a pic of a standard tranny mount crossmember.
Old 01-17-2012, 12:10 AM
PaulSwany's Avatar
Re: Manual Transmission Mount
I'm looking to replace the same thing. Welded in a auto trans mount... but it keeps breaking.... Has anyone replaced this mount on the V6?
Old 01-17-2012, 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Back from the dead. You welded in the cross member or the mount? Which keeps breaking (the mount I assume)? V6 or V8 makes no difference. The following link may provide some insight:
https://www.thirdgen.org/forums/tran...-should-i.html
BTW, if you welded in the cross member, may I ask why?
JamesC
Old 01-17-2012, 07:44 AM
PaulSwany's Avatar
It's the rubber mount that keeps breaking. I welded the metal part of the vulcanized mount to a bracket I made to adapt it to the fluid mount style cross-member. I just found a cross-member on eBay that I hope will resolve this problem.
Old 01-17-2012, 07:47 AM
PaulSwany's Avatar
I got the cross-member that has the secondary rubber donuts hoping that will dampen the vibes some.
Old 01-17-2012, 07:51 AM
JamesC's Avatar
It will, but you might check for the availability of the 'donut's themselves--like all rubber they deteriorate. The secondary cross member will accept the standard OE mount. I dumped mine along ago for the one-piece. I don't recall there being any more vibrations with it than with the secondary.
BTW, welding may well have caused the rubber to fail.
JamesC
Old 01-17-2012, 07:58 AM
PaulSwany's Avatar
I found these at Autozone: http://www.autozone.com/autozone/par.../N-ih4itZ6o36u
Old 01-17-2012, 08:04 AM
JamesC's Avatar
I ran those at one time, and quite frankly, the vibration and harmonics at higher RPM was more than I could bare. I swapped the poly out for OE rubber which I purchased at my dealership (but that was a number of years ago). If you're attempting to eliminate vibration, you won't be satisfied with the above.
JamesC
Old 01-17-2012, 08:05 AM
Car: 1989 Camaro RS
Engine: 2.8L V6
I found a used cross-member for a V8 on E-Bay and then purchased a new aftermarket mount from Summit. I had to elongate the slot where the mount attaches by a quarter of an inch with a rat-tail file but the rest bolted up nicely. It does vibrate more than the stock V6 version but not enough to bother me into shelling out $300. Total cost for my repair was about $40 with the used cross-member and a new mount.
Old 01-17-2012, 08:21 AM
JamesC's Avatar
I think the bolt on the poly is larger than OE, as I was forced to do the same on an after market cross member. Here's a comparison of standard mounts for those who might be interested:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
jhawkeye
05-25-2022 06:33 PM
angel2794
Theoretical and Street Racing
24
07-01-2021 11:54 PM
Vintageracer
01-10-2020 05:33 PM
bjpotter
01-22-2019 12:27 PM
smokingss
LSX and LTX Parts
03-03-2016 07:40 PM
Quick Reply: Manual Transmission Mount
