What series gears and carier do I have? -87 L98 GTA
Old 06-02-2004, 08:00 PM
stiers's Avatar
I don't have my RPO codes anymore and I am trying to figure out what carier and series gears I have so I can upgrade my GTA from 3.23s to 3.73s. Anyone know where to look or have an answer?
Old 06-02-2004, 08:17 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Pull the cover, look for the stampings on the edge of the ring gear and end of the pinion gear.
If 3.23, that's 3-series. Assuming someone sometime in the past didn't change from 2.73's with 2-series 3.23 gears.
Old 06-02-2004, 08:26 PM
MdFormula350's Avatar
87 IROC-Z
Formula
Trans Am
GTA A4 L98 V8 9.3:1 5.7 (350) 225@4400 330@2800 TPI ---- ---- 3.27* ----
*Borg-Warner rear axle
looks like u have a 9 bolt.
www.9bolt.com
Old 06-02-2004, 08:47 PM
stiers's Avatar
Is that a good thing or a bad thing?
Old 06-03-2004, 08:32 PM
good i guess, its a real strong rear end.
Old 06-03-2004, 10:16 PM
stiers's Avatar
I looked at 9bolt.com and didn't really see much there as far as information or pricing for gears. How much am I going to have to spend to get a set of 3.73s for this rear end?
Old 06-03-2004, 10:40 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
A lot. I can't remember where, but I priced out gears for a 9 bolt and it's like $400 for a gearset instead of the $179 for a 10 bolt gearset. And 9 bolt's have weird gear ratio's so you might not see a 3.73 ratio per say, but something close like 3.70 or something.
Old 06-04-2004, 01:25 AM
stiers's Avatar
Thats not what I wanted to hear I guess she isn't going to be getting new gears anytime soon. $400 isn't worth the jump from 3.23 to 3.73
Old 06-04-2004, 09:57 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Parts for 9 bolts are more expensive because they arent nearly as common as a 10 bolt. They are quite a bit stronger than the 10 bolt though. Theres a few companies that make gearsets for them and one company makes axles for them. If 3.45s would be good enough for you, than 5 spd cars with G92 came with those so you could find a used set for pretty cheap.
hectre13
12-11-2023 08:14 AM
Scorched1984
Wheels and Tires
66
04-16-2016 06:56 PM
hectre13
08-26-2015 08:17 AM
Navy8125
08-25-2015 08:25 PM
Winchester1094
08-18-2015 10:23 AM
Quick Reply: What series gears and carier do I have? -87 L98 GTA
