9 bolt carrier....decoding?
Car: 1989 Camaro Iroc-Z
Ok, I just got a great deal on a new carrier. i just want to make sure its the series 3. What #'s on the carrier tell you?
Justin
Justin
if it's a great deal for a 9 bolt carrier i wouldn't worry aobut the series, you can always resale it. easiest way to tell is to look at them. do a search here and you'll find pics of the 2 side by side
Casting #'s
I Roc A Z:
Most common "3 series" differential case number:
0578-908-F- 731 fits 3.27 ratios and numerically higher.
Should also be marked with Aust. Patent No. 222888.
Hope this helps.
By the way, people, the carrier is the casting with the axle tubes pressed and welded into it. What so many of you are calling a carrier, is a differential case.
Don
Hope this helps.
Don
UltRoadWarrior9
09-02-2015 08:24 PM
