vss tranny to mech speedo...opposite of what most people do
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I have v6 gauges for my 89 RS with a 2.8. I'm going to change the resistor in the tach cluster to make it compatible for an lt1. The other gremlin I'm chasing is the speedo is mechanically driven, but the transmission (a '95 46le automatic) is vss driven. How can I make this setup work? If this is in the wrong forum moderators please move it.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Search around on the net for the abott cable x its a box that will spin your speedometer using an electronic signal.
Thanks a lot z28r!cer I found it in a matter of seconds thanks to google. I am going to call them today and see how much it'll cost.
As far as getting a different gauge cluster, it just seems like too much work from what I've researched because you have to change out the dash or mod the dash to get it to fit, plus I like the older gauges better.
Car: 93 240SX
Engine: LQ9
Originally posted by firebirdjosh
It's probably cheaper to just get a new gauge cluster from a later car, they are dirt cheap.
The changeover can be done, but it would be a lot easier to just buy the box, iirc its like $250 or 300
Car: 93 240SX
Engine: LQ9
Originally posted by jmd
Unbolt the tailhousing.
Remove the VSS reluctor.
Install speedo gears.
Install correct tailhousing (Not even sure that it's different...)
Done.
Now as for what controller with which you are operating your 4L60-E, I don't know what VSS signal you're giving it...
Done.
However the big flaw in your plan, I want to see where you are now going to get him a 64,000 pulse per mile input for his LT1 computer.
Originally posted by Z28*****
Not so sure the reluctor can easily be removed, the one i've opened up looked like it was a press fit on the shaft and not easily removed.
I read 2.8, didn't get to the LT1 part.
There are no "per mile" VSS when they are reluctor ring. It's "per driveline revolution." It's best not to discuss VSS in those terms.
There are tailhousings that allow mechanical cable + VSS reluctor. Jagsthatrun is one source of info / parts. That's probably what I'd do, although I may change my car to elec. speedo.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The gauge cluster doesnt bolt right in, the entire dash shell is a different piece. And before you open your mouth and say just change the shell, the metal brackets at the end of the dash which are welded to the body are also completely different.
:There are tailhousings that allow mechanical cable + VSS reluctor. Jagsthatrun is one source of info / parts. That's probably what I'd do, although I may change my car to elec. speedo.
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
If the reluctor wont come off you could have a trans shop swap the output shaft and gears with the ones from the 2.8s trans. While there changing shafts they could check the internals of the trans for wear and save you from having to remove the trans later.
TMZIrocZ350
10-07-2015 12:09 PM
