700R4 valve body
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
700R4 valve body
Seeking much needed help from anyone. I F'd up the valves from the valve body. I removed everything from the valve body to clean out all the burnt clutch debris. I had everything layed out on a clean sheet of cardboard. I was cleaning everything a during the process bumped the cardboard. All the valves swarmed each other and now I'm up $hit creek without a paddle. I can tell where about half of the stuff goes.
Someone out there has to have made the same mistake as I have. I just need a diagram or photo of the valve lined up in front of there hole. If someone can share this or tell me what manuel I can find it in that would help. I have the haynes manual and it does not have the diagram I need.
Please help a brother out so I can get the "Z" back on the road.
Axle/Gears: '01 3.42 10 bolt
contact a local tranny parts place or even a shop and get a ATSG manual for it. a shop might be able to make a copy for you. a parts place will sell you the manual. it is a must for any rebuild. lots of good info and diagrams of the valve bodies!
Car: 91 Z28 CAMARO
Alls good in da hood. I remembered that I printed out some info on the tranny and there just happened to be a photo of everything layed out. Here is the link if anyone is interested.
http://www.mez.co.uk/Chevy700r4pg.3.html
