245/50 15" tires, any alternative?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
ive had 245/50 15" on my car for a few years now, they are bf goodrich euro ta which they no longer make, im limited to one tire now, the dunlop sport sp8000.............................is there another size that would be very similar that would give me more options? i picked the 245/50 years ago when i saw them on an iroc, i believe they were 16" however i like the width on these , actually a smaller sidewall would be nice too but i think thats pushing it
bueller?
thats less side wall? i thought the second number was the width
Car: 86 Iroc
Engine: 305 tpi lightly modified
Axle/Gears: 4 10's
eh, nothing else will fit on a 7" rim it seems, nothing as wide with shorter sidewall anyways
Car: 86 Iroc
Axle/Gears: 4 10's
I would think you have 8" wide rims don't you.Bf might not make that specific tire in that size but there's alot of other brand options that will.Go back to the link I previously posted.They have allot of brands and options within those brands and then show the sizes available,I know bf has a tire called G-force sport in a 245/45 15".I hope this helps,but I'm a little confused exactly what your lookin for.
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
how about 255/60/15's
ive got 255/60/15's on my car. they were my stepfathers tires. i needed a tires when i bought my car, he had these tires goodyear eagle GTII's that he had on his 84 z28. he cant use them anymore becuase i know has a set of 16" IROC wheels. anyways i love the way they look on my car, really give it a performance look. i also think they help a little with handling, im not sure about that but i suspect it handles better with those than with factory sized tires. just a suggestion becuase i like them
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My son's 91 RS had 265/60 15's on the factory rally wheels when we bought it. Never any rubbing issues in the back. The front didn't rub till we put that great big WS6 sway bar on it. Ended up with 235/60's up front to eliminate the rubbing in a sharp turn
1 Post
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
This might not be very helpful, but your 15X7 wheels are going to be a problem if you want a good contemporary performance tire, especially for handling. Even a set of stocker IROC or Z 16X8 wheels would make things easier for you.
As for availability, go to tirerack.com, do a 'search by tire size', and it'll show you just about every tire on the planet in your size. Then pick a tire and click 'specs' to get tons of info on other sizes.
yeah , i buy all my tires from tire rack , yep, i have 15x7 rims, so it seems im limited to that tire, nothing else ive found in a search will fit on a 7" rim......i have centerline convo pros......................
Hotrodboba400
12-10-2019 07:07 PM
