setting the 700r4 TV cable, mine doesnt pull any of the cable out at WOT
i have a stock factory all original 84 with LG4 and 700r4
when i slide the TV cable housing all the way back and then open the throttle to WOT all the way it does not pull any of the cable sheath out of the housing and make even a single click, normall when you set these they make a few clicks and pull some of the cable out of the housing past the first click even
it is 2.73 axle ratio and i notice that when im cruising at 35 or so it is in higher of a gear than it should be at that speed because when i go to speed up a little it is practically at idle speed,
but if i get on it pretty good then it will kick down
the trans shifts too soon, it seems
remember its totally stock factory original 84 LG4 305 and 700r4 even still the original CC Q jet
comments? ideas ? suggestions ?
thanks
thanks
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
sounds like the cable is either broken or stretched inside the sheath. I would just replace it and be done with it, there cheap enough.
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
My car just started to do the same thing. I'm replacing the tv cable tommorrow. Let you know if it fixes the problem.
i didnt think it was possible for this cable to do such a thing, never heard of it happening before
new one on me
are we for sure that it does/can ?
positive ?
but it definitely hits third gear wayyyyyy too soon
it drops into 3rd before 35 even at normal acceleration
with 2.73 axle even
im gonna have ot manually shift it from 2 to 3 until i figure it out for sure it looks like
thanks
new one on me
positive ?
with 2.73 axle even
thanks
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Originally Posted by Forshock 85TA
dont drive it until you fix it. Gonna fry it.
If you continue to run this tranny you may as well be looking for a new one, you will cook it in a hurry.
It does sound like the cable has broke or come off the linkage in the tranny. By the sounds of it the tranny isnt getting a signal of any throttle being applied and just upshifts right away.
9192camaro
16
02-03-2019 12:21 AM
mdtoren
08-16-2015 05:45 PM
