Transmission end play???????????????
Old 05-05-2007, 08:15 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I just rebuilt my 95 4l60e transmission and when I got to the point to check the end play, I found that I have none. I rebuilt the tranny with a probuilt kit and a TCI input shaft/drum because the stock one was cracked. The probuilt kit came with a #68 selective washer (same as stock), now the TCI kit came with a new lo reverse roller clutch race to accept a bearing. I compared the stock race and thrust washer with the TCI race and bearing, and the TCI race and bearing measured a few thousands smaller. So with the #68 selective washer and the new race with bearing I should have more end play, right? I am confussed and trying to find out what is wrong here, or if I just have to put a smaller selective washer in. I Know that everything is in right, all the way down to the position of the bearings. How critical is end play?
Old 05-05-2007, 09:52 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Transmission end play???????????????
Endplay is nescessary to allow the internals room to grow whan warm. If you have negative endplay, something is misassembled.
Old 05-05-2007, 10:31 PM
Car: 1987 firebird
Transmission: 4l60e
Nothing is mis-assembled, I have been over the tranny many times?
Old 05-06-2007, 02:27 AM
Pro Built Automatics's Avatar
You can try the #67 washer here (it is the thinnest). Do you get any clearance now? Let me know what happens here?
Old 05-06-2007, 10:02 PM
Car: 1987 firebird
Transmission: 4l60e
I took the tranny apart and reassembled it the exact same way, and now it has .030 end play. Somthing must not have been seated correct the first 2-3 times?
I do not know, as long as it has end play now?
AussiePr0nCar
03-06-2020 04:04 PM
Azrael91966669
25
06-20-2017 04:04 AM
sweet_87_iroc
09-25-2015 10:01 PM
86White_T/A305
08-17-2015 12:16 AM
mizz0313
08-12-2015 06:45 AM
Quick Reply: Transmission end play???????????????
