PATC VS. Probuilt
Old 02-13-2008, 10:12 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
PATC VS. Probuilt
I have a solid 91 700R4 that i am going to get rebuilt and i want it built proof. The core only has 70,000 miles on it so i am sure the core is solid. who would you chose to get the parts from Probuilt or PATC. If i go PATC should i get the gm 5 pinion planetary gear and the torque master kit.
Probuilt
PATC
also what is a good size stall for me current mods, mods in sig.
I have plans for a world 427 small block with 13 to 1 compression running on E85 in the 650 na fwhp range for next winter. That is why i want a very strong trans.
Old 02-15-2008, 05:30 PM
z28z34man's Avatar
Re: PATC VS. Probuilt
Probuilt 700R4 Rebuild Kit-Street/Strip 1988-1993
"Front Pump"
Seal retainer
Seal, late design
Teflon bushing, late design
10-vane rotor with vanes, slide, rotor guide & pin assembly
Steel rings & priming spring (Trans-Go) above or below 5,500 rpm WOT shifts, please specify
New design pressure regulator valve
Intermediate/reverse boost valve .296
Main boost valve .500
New Stator support with wide bushings
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .078
4 Reverse/input "low drag" Turbulator steels .078
1 Reverse waved steel (eliminates the belleville spring that tears up the inside of the drum)
5 Borg-Warner forward clutches .070
5 Forward steels .090
2 Borg-Warner overrun clutches .078
2 Overrun steels .091
5 Low/reverse clutches, Borg-Warner .087
5 Low/reverse steels, Turbulator .068
Your choice of the Borg Warner Hi-Energy, 8 clutch setup for the 3-4 pack below,
8 3-4 clutches (Hi-Energy), Borg-Warner .080
3 3-4 steels Kolene .060
5 3-4 steels Kolene .080
2 3-4 pressure plates .128
1 3-4 snap ring .062
or the "modified" Raybestos Z-Pak, 16 one sided clutch/steel setup for the 3-4 pack.
16 one sided clutch/steel arrangement
1 5-tang apply ring
1 3-4 bottom pressure plate .128
1 3-4 top pressure plate .145
Your choice of the input sprag below
Borg Warner dual cage 29 element design
or the Raybestos SKF single cage 29 element design
"Other" (these are additional parts that come in this kit)
Sealed Power Beast sunshell
Trans-Go (Hi-Rev) replacement forward & 3-4 release springs (good up to 7,800 rpm)
Input/output shaft seal (Viton)
2-4 band (Hi-Energy), Borg-Warner
2nd gear servo, Corvette
Borg-Warner Low/reverse roller assembly (late design)
Paper & rubber (gasket) kit
New governor gear
Case connector 3 prong
Transmission filter (OEM)
Converter solenoid & governor filter
Bushing kit with 3 teflon
Thrust washer kit
Sealing ring kit
HD Torrington Bearing kit
TransGo Shift kit (Street/Strip) w/accumulation for nice part throttle shifts
Vamac 3 lip rear seal (prelubed)
Two new accumulator pistons
New oem pins for forward & 2nd accumulator
Price: $496.34
__________________________________________________________________
PATC Master 700 Raptor Rebuild Kit (Turbo Don Special).
This package deal comes with : Alto master rebuild kits with an 8 clutch Red Eagle Power Pack and full thickness Kolene steels for the 3-4 clutch, pump bushing, case bushing, pump seal retainer, filter, performance torque converter with your choice of stall speeds up to 2800 RPM (#2), thrust washer kit, high performance Superior intermediate billet servo (not Corvette servo), high performance Superior overdrive billet servo, the .500" Mega Valve, an oversize low / reverse boost valve, 29 element forward input sprag, 10 or 13 vane pump kit, Alto Carbonite PowerBand with thicker hardened anchors that holds in second and overdrive, 4th gear converter lock-up switch, "The Beast" reaction shell, performance 1-2 accumulator spring, special intermediate servo release check valve, high output pump slide spring, 2 new accumulator pistons, wide sun gear bushing, wide stator support bushing, performance Transgo separator plate, elevated pressure regulator spring and the freight is included anywhere in the 48 United States. All of this can be yours for $921.00
Extreme Duty Torque Drive Package
. You get a hardened input shaft and drum assembly plus a hardened reaction shell and bearing. Every time you think there's nothing else that can be done to a 700R4, here it comes. These parts are made to with-stand way over 600 foot pounds of torque. Fits late 1987 up.
Drum: Starting with select cores, the input shaft / drum assembly is disassembled and visually inspected. Then super heated until fully expanded and then X-rayed for internal cracks. Heating the drum collapses any carbon pockets thus ultimately strengthening the cast and stabilizes it. This process is followed by a flux test to determine if any external fractures are present. If all checks well a specially machined alloy support ring is then married to the drum.
Shaft: The shaft is cold and hot chemically forge treated to a military standard Rockwell 38 hardness. Then stress relieved which gives the shaft double the strength of its stock counterpart. The parts are reassembled and spun balanced at 9500 RPM. This step insures that this assembled unit will spin true with absolutely no harmonic vibrations to disturb engaging parts. Stock factory units were never balanced to this degree. The input shaft / drum assembly comes with a specially machined over-run piston and high temperature seal.
Extreme Duty Shell / Bearing Assembly: A new reaction shell is provided with a reinforced hub that is approximately twice the thickness of an OEM reaction shell. The reaction shell is hardened then spun balanced at 9500 RPM. We replace the OEM plastic thrust washer with a roller thrust bearing to reduce heat. A specially machined and hardened rear planetary inner race is included to complete the assembly. Call toll free 1-888-2012066 for your special price. Sale! Buy a 700 Raptor transmission and add the #45 Torque Drive Package as an upgrade for $187.00. This is a full $111.00 savings.
For farther information on these parts please call toll free, 1-888-2012066. We use these parts in our level four 700 Mega Raptor and 700-E Mega Raptor transmissions. Cost $298.00.
what one is better for my application
Old 02-15-2008, 11:23 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: supercharged 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ive always bought from PATC and there products are great. i got there raptor blood, boost valves, billet servos etc and theve been great. but i need to overhaul my trans to handle 500 NA hp and 650 boosted. i asked around and everyone swears on probuilt. eventually dana himself wrote on my thread and told me to call him. so i did and he really knows his stuff, he told me what i would need and he worked with me and asked me all about the car it was going in, the motor, the gears, how i drive and what i want. he was even able to tell me something with motors that affect trannys and what he would recomend with my motor for longevity. he didnt try to sell me anything i didnt want and told me exactly what i needed and worked out a deal/package. he spent about 20min on the phone with me. dana really knows his stuff, not to mention they are alot cheaper than PATC. i will be going with probuilt when it comes time.
Old 02-16-2008, 12:38 PM
z28z34man's Avatar
thanks i will give him a call next week
Old 02-16-2008, 01:46 PM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
I had a Raptor in a 496 Big Block 4x4. It was the best money I ever spent.
Old 02-16-2008, 11:17 PM
86_Dan_Z28's Avatar
Car: 86 Z28
Do a search and see who has the most positive feedback, then decide who to buy from.
Old 02-17-2008, 12:51 PM
z28z34man's Avatar
i did search but there is really no bad reviews of ether out there. Probuilt is cheaper but they don't offer some of the parts PATC has ( like the gm's 5 pinion planetary or there new 6 pinion planetary ) so it is a tossup depending if i need that strength.
also what size and rpm stall should i get.
Old 02-17-2008, 05:45 PM
Pro Built Automatics's Avatar
I have nine & ten second vehicles out there using the 4 pinion planets, and they are not breaking them. I have only seen one in the last 12 years break, so I do not think they are weak. So save your money on this. The Alto clutches do not hold up well in the 3-4 clutch pack on 700R4's or 4L60E's, that is why I recommend the Borg Warner Hi-Energy's here. If you want the larger 2nd apply servo I carry and use the Sonnax version which is much easier on the transmission. The billet is to hard on parts. You only need the large 4th gear servo if you are going to make WOT 3-4 shifts all the time. If the transmission came with a 13 vane pump, (no 700R4 did) you can use the 13 or 10 vane setup, if it did not come that way, you "must" use the 10 vane setup, as the back half of the pump has different port slots to work with the 13 vane slide and rotor. If you want the strongest rated kit in terms of horsepower and torque, then go with the Pro Street Elite https://www.700r4l60e.com/store/prod...&cat=19&page=1 Nobody has a kit close to this. DANA
Old 02-17-2008, 06:05 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
hey dana i was interested in buying a kit from you to help a friend rebuild his trans. but i noticed that when i clicked on contact it said "due to a death parts wont be shipped till 10/30". does that mean october 30th? i just wanted to check before i tryed buying a kit from someone else. i bought my trans kit from you and i really like it and my friend really wanted to use your parts.
please get back to me
Old 02-19-2008, 04:34 AM
I need to talk to my webmaster on this as this was last year. It was due to a combination of several deaths in the last 2+ years. Mother & father inlaw, Grandson, and a few good friends. Just needed to get away. I am back working harder than ever. Let me know if I can be of help? Dana
Old 02-20-2008, 01:00 PM
Shagwell's Avatar
Car: projects.......
Dana deffinitely knows his stuff. I've previously ordered all(I've built several now for different projects/people) my parts through PATC, but it's probably time I give him a try. I can't say cheaper or not, haven't checked.
Personally, I've had no problems with the alto clutches, even with over 25k miles in the blown big-block truck. I have also run the BW hi-energy setup and have not had any issues from it either. I agree on the planetaries, the only reason you hurt the 4 pinion is if you have overly aggressive part throttle shifts(meaning B&M "kits"). I have always used the billet servos in performance builds, the vette servo for regular rebuilds, I won't use the standard stockers at all. Not sure about their use with the transgo shift kit, I have previously only used the superior valvebody kit + the large boost valves. Unless you're gonna run fairly high rpm (7k +) the 10 vane pump is plenty capable.
As for the converter, either buy one now to suit what you have and then buy another when you change powerplants, or wait and just buy one for the new power plant. - Deffinitley don't put a used one in front of a new trans w/o having it flushed and/or cut open and checked. Either way, you can't buy parts suited for a future combination and install them on what you have unless you're satisfied with less than optimal results. - Every component is part of a "package". If any component does not suit the package, it will under-perform accordingly.
Hey Dana, do you offer any parts for the 4L80E? (too lazy to check right now....)
Old 02-20-2008, 04:02 PM
z28z34man's Avatar
i am thinking a Vigilante 3200 would be good for booth enines and i can get it restalled if i need too.
Old 04-25-2016, 09:48 AM
Chris1978's Avatar
Hi Dana,
been trying to get hold of you in several ways, I'd like to buy your 700R4 product - are you still active in the business?
Regards,
Chris
Old 04-26-2016, 02:24 PM
I am here. Best to call in the early afternoon. 909 795-1876
Old 04-26-2016, 03:25 PM
Chris1978's Avatar
That's really good news, will try after lunch then. Emailed you as well, so I'm in your inbox as well as having placed an order in your system that only needs payment Sir
Christopher Grods
3.8TransAM
09-17-2015 02:16 PM
GTAman
09-14-2015 09:53 AM
GTAman
08-27-2015 10:29 PM
92RSB4C
10-18-2001 05:49 PM
Quick Reply: PATC VS. Probuilt
