which cross member, t56 swap with mufflex
Car: 1989 Gta
Engine: 383
i have hooker 2 3/4 long tubes into mufflex 3 inch Y pipe into 4 inch single. I plan to use the stock torc arm which cross member are you guys using
SPD? Spohn? or weld up your own? The car is stock ride height i do not plan to lower it but don't want to sacrifice ground clearance.
Thanks for your input
nick
nick
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Re: which cross member, t56 swap with mufflex
http://www.skulte.com/product_info.p...f8743de24b816a thats the one I used...Works perfectly with the mufflex y-pipe. Spohn will not work without major mods...
1992 Trans Am
08-08-2015 08:16 PM
