how do u get to the top to transmission bolts
Old 03-31-2008, 09:47 PM
camaro_tim81's Avatar
Car: z28
Engine: 402 Big Block
Transmission: th350
how do i get to the top two transmission bolts with out take out the eng? plz help me thank you
Old 03-31-2008, 09:59 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: how do u get to the top to transmission bolts
I got to mine with a wrench fairly easily. I think I had the distributor out so you might want to pull the distributor.
Old 03-31-2008, 10:01 PM
Stevo's Avatar
Car: Pair of 92 Z28s
36" of extension and a 9/16" swivel.
Old 03-31-2008, 11:00 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I got to the top two with either just a wrench or a ratchet with a short socket. The bolts in the middle on either side were the ones that required a 36" extension and a swivel. Either way, the engine has to be tilted down. I didn't have to take the distributor off, but be careful how much you lower the engine or you will damage the cap.
I should also tell you that the way I did the 36" extension was by taking a bunch of 4" and 6" extensions and piecing them together. It will give you just a little bit of wiggle and possibly save you the effort of working with a swivel.
Old 04-01-2008, 07:43 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I let the engine/tranny tilt down towards the back of the car and about 2' extension with a impact gun. If you leave your distributor in, make sure it doesn't hit the firewall.
Old 04-01-2008, 08:21 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
You guys are going to great lengths to get the bolts out. I was always able to get the top four with a wrench and the bottom two with a rachet.
Old 04-01-2008, 08:26 AM
Dokken10's Avatar
Car: 91 Formula
If your intake/wiring harness etc. is still on, its damn near impossible to get to the top 2 bellhousing mount bolts with a wrench.
Old 04-01-2008, 11:17 AM
Car: z28
Transmission: th350
i can loosen the eng mounts and it will tilt the eng but i dont got a eng lift
Old 04-01-2008, 11:25 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Jack back of the transmission up all the way and you can then reach them from behind the engine leaning over the the engine compartment.
jhawkeye
05-25-2022 06:33 PM
midge54
12-27-2019 04:14 PM
Reddeath210
10-06-2015 08:20 AM
gta90
09-15-2015 04:00 PM
Quick Reply: how do u get to the top to transmission bolts
