Why does my limited slip rear end only spin one tire sometimes??
Old 09-25-2000, 03:55 PM
brent walden's Avatar
I have a limited slip disc brake rear end out of a 91 Z28 and when I turn to the right and floor it, only the right tire spins but when I turn left they both spin. Also when I go strait or power brake it they both spin. I just don't understand why it only spins the right tire when I turn to the right.
Thanks!
Brent
Old 09-25-2000, 06:33 PM
crazeinc's Avatar
Change the fluid and add some limited slip additive and see if that helps at all.
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(383 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old 09-25-2000, 07:31 PM
do I have to change the rear end fluid or can I just add the limited slip additive? My rear end fluid really isn't that old maybe 5-6 Months. Also where can I get limited slip additive?
Thanks!
Brent
Old 09-25-2000, 09:25 PM
ede
ede's Avatar
it's really hard on rear ends for you to do burn outs while turning. i'd change the lube and add the posi additive.
ICON MOTORSPORTS
Old 09-26-2000, 03:14 PM
89IROCZ
Guest
Posts: n/a
OK... but explain this...
I have the stock 3.23 in my 89 IROC and I can pretty much only get two tires spinning if I am power breaking with the 700R4 shifter in "2" or "D." If I do it in "1" or "OD" it only spins one tire.
Can anyone explain this???
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old 09-26-2000, 03:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get the limited slip additive at your GM Dealer. It costs about $10. Use only the GM additive, because its the one that works the best.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
hectre13
12-11-2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
sweet_87_iroc
09-25-2015 10:01 PM
mizz0313
08-12-2015 06:45 AM
novaderrik
08-10-2015 12:44 PM
Quick Reply: Why does my limited slip rear end only spin one tire sometimes??
