Stock shift points for 700R4?
Old 07-30-2008, 08:25 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
What are the WOT, stock shift points for a 700R4 in RPMs, for the 1- 2 shift, 2-3 shift, and 3-4 shift?
Old 07-30-2008, 08:28 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Stock shift points for 700R4?
its hard to get the exact shift points, but before i installed my shift kit mine shifted at 2800- 1-2 shift, 3100-2-3, and around 3600 for 3-4. But now my shift points are all higher then that due to the shift kit bein installed. but these points are when i leave it in drive not when i manual shift.
Old 07-30-2008, 10:16 PM
4ormula's Avatar
Car: 1989 Pontiac Formula 350(Maui Blue)
Engine: 355 TPI,accell superram,full roller
Transmission: Street/strip 700R4
Axle/Gears: Australian 9, 3:27 ratio
The only one I remember before I built my 700 r4 was that 1st gear stock shifted at 4,200 rpm on mine
Old 07-30-2008, 11:24 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'll go for a drive tomorrow and find out. As far as I know, my car is bone stock other than the suspension stuff I have done.
</div>
Old 07-31-2008, 03:54 AM
Pro Built Automatics's Avatar
Assuming that the TV system is working correctly, and the TV cable is adjusted correctly, the inner and outer governor weights, and the 1-2, 2-3, 3-4 shift valves, and the spring operating the shift valve, etc. determine what rpm the engine will shift at any throttle opening. The high rpm Corvette governor and valve body are matched to give apx. 5,800 rpm WOT shift points. The high rpm Z-28 governor and valve body are matched to give apx. 5,500 rpm WOT shift points. Typical V-8 governor and valve body are matched to give apx. 4,800 - 5,200 rpm WOT shift points. Then the diesel.
Old 08-01-2008, 01:35 PM
Car: 1987 IROC-Z
Transmission: TH350
This is what I got for shift points.
1-2: 4,800
2-3: 4,600
3-4: I was already going 87 in a 65 zone half way through third so I figured I should shut it down.
I don't think this should matter to shift points but I have the stock 2.73 rear gears.
Mike</div>
Old 08-01-2008, 02:18 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
mine will shift a full throttle at about 5500-5800
Old 08-01-2008, 02:57 PM
chazman's Avatar
Axle/Gears: BW 3.45
1-2: 4,800
2-3: 4,600
Mike</div>
Thanks Mike. That's quite abit different than mine. I've got an '83 LU5/2.93 rear. Mine is more like:
1-2: 4200
2-3: 3500
3-4: 2500
Old 08-01-2008, 03:29 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
5500 RPM when mine was 100% stock. The 1-2 would shift a bit higher. Around 5800'ish.
Old 08-05-2008, 12:09 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Mine also shifts somewhere between 5500-5800. Right when my tach hits the orange. As far as I know, it's bone stock.
Old 08-05-2008, 03:17 PM
chazman's Avatar
Axle/Gears: BW 3.45
I wonder if one of these things will help my tranny shift like your's guys? http://cgi.ebay.com/ebaymotors/700R4...mZ140076321506
Old 08-05-2008, 11:42 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My Tac shows me shifting at 5500 RPM at WOT. My laptop and Datamaster program tells me it is shifting at 5000 RPM at WOT.
Old 08-07-2008, 09:38 AM
The 700R4 Throttle Valve Cable Corrector Spring is to help part throttle shifts that are too early, it will make them later. It does not change WOT shifts.
Old 08-07-2008, 08:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I stomped my G20 van after putting the original stock 1983 Governor in it and it held right up to 5,000 rpm on both the 1-2 and 2-3 shift. By the time I hit 3rd gear and went a few seconds with 3.08s and 29" tall tires I was running 100+ in a 70 so I shut it down.
http://s243.photobucket.com/albums/f...t=101_1403.flv
Old 08-08-2008, 04:51 PM
chazman's Avatar
Axle/Gears: BW 3.45
What effect does it have on downshifts?
Old 08-08-2008, 05:24 PM
Easier to get.
Old 08-08-2008, 05:41 PM
chazman's Avatar
Axle/Gears: BW 3.45
Easier to get.
Thanks, and one more question for you. The previous owner (I've had the car a couple of months), said the trans was rebuilt with a "Corvette servo". What affect would that have on an otherwise unmodified 700R4? Could it be a factor in my low WOT shift points?
Old 08-17-2008, 07:22 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
im kinda having a hell of a time getting my 700 i built up to shift at the time id like.
The part throttle is way to low for me but when i get it pretty close to what i want, the 1-2 shift bounces off my rev limiter a few times at 6K then shifts, but the next shift is aobut perfect at 5300 or so...
Kinda sounds like i need that tv spring.
Honestly my main concern was the 2-3 shift was way to early, it would just barely bind (shift overlap i assume) on the first shift it makes when i take it out, i still dont know why, but with the part throttle shifts jacked up a little bit, u dont see the problem anymore. not to hyjack just wondering.
Old 08-17-2008, 07:50 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
The Corvette Servo just has a bit larger surface area on the pistons for a stronger/firmer shift. It will be a bit better for the band that way. I think it does more for shift quality than anything else.
Azrael91966669
25
06-20-2017 04:04 AM
italiano67
12-11-2016 09:21 AM
TreDeClaw
08-14-2015 06:58 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: Stock shift points for 700R4?
