How to measure backlash with a dial indicator? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 08-04-2008, 02:20 PM   #1
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I have to re shim my carrier. I bought a dial indicator and some shims. How do you hook up a dial indicator to get the correct measurement? What's the best process for getting the correct backlash?
SDalt404 is offline vBGarage Page   Reply With Quote
Old 08-04-2008, 02:36 PM   #2
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How to measure backlash with a dial indicator?
Attach the magnetic base somewhere so the dial indicator can sit on a ring gear tooth. Hold the pinion so it doesn't move and gently move the ring gear back and forth just enough to measure the backlash. If you move the pinion by moving the ring gear, you're not measuring backlash.
On a GM differential, backlash is adjusted by changing the shim thicknesses but the bearings also need preload so a case spreader is normally used to get the shims in and out.
AlkyIROC is offline vBGarage Page   Reply With Quote
Old 08-04-2008, 05:28 PM   #3
SDalt404's Avatar
Car: 1988 GTA
Seeing that I don't have a case spreader, am I going to be a able to preload the bearings?
So if I get this right, I have to measure backlash and get it within specs. Then I have to add .004 thickness to each of the sides which will require some sort of spreader to get the shims in.
When you say, "sit on a ring gear tooth", what exactly do you mean? The edge of the tooth? What is the angle the indicator needs to be at?
Old 08-05-2008, 02:21 AM   #4
stroker86's Avatar
Car: 1986 Camaro Z28
Engine: 383 cu in
Transmission: 700R4 with upgrades
Axle/Gears: 3.23 posi
you should set the indicator tangent to the ring gear. so, the gear being in the vehicle and looking at it from the rear of the car, the indicator being mounted in a vertical position. the middle to outside edge of the tooth is where the end of the indicator needs to be when measuring.
stroker86 is offline vBGarage Page   Reply With Quote
Old 08-06-2008, 07:16 AM   #5
Here's a picture of how I had mine setup. A case spreader is absolutely not necessary. If you have to use a hammer and a flathead screwdriver, or even better, a brass drift, to be able to tap the shims in on each side, then it will be tight enough to preload the carrier bearings properly. You want your backlash to be .006"-.010". That's the proper range. Once you get the backlash set right, you might need to add about a .002" thick shim to each side to get the preload tight. Just make sure to use the same thickness on both sides so you don't change the backlash.
Pat Hall is offline vBGarage Page   Reply With Quote
Old 08-06-2008, 11:11 AM   #6
SDalt404's Avatar
Car: 1988 GTA
Thanks for the advice and the picture. I think I can do this now!
Thread Thread Starter Forum Replies Last Post
Possible Touchscreen 1.5 din option? hectre13 Car Audio 22 01-30-2017 12:44 AM
Vogtland Spring Install 87v6Bird Suspension and Chassis 14 09-18-2016 12:17 PM
1991 Camaro Speedometer Board; Broken, now working! Elephantismo Electronics 12 11-14-2015 10:40 PM
V8 T5 Shifter location. AUZ28 Transmissions and Drivetrain 4 10-03-2015 07:28 PM
backlash and carrier shims gord327 Transmissions and Drivetrain 19 10-03-2015 02:25 PM
Go Back   Third Generation F-Body Message Boards >
Tags
attaching, backlash, dial, differential, end, indicator, magnet, measure, measurement, measuring, pinion, rear, ringer, set, spline, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
