6 speed 4L80E - Third Generation F-Body Message Boards
6 speed 4L80E
Thread Tools Search this Thread
Old 08-05-2008, 01:39 PM   #1
6 speed 4L80E
I'm doing some research on the 4L80E as I'm thinking of doing a 60E to 80E swap and came across the topic of a 6 speed 4L80E. I remember seeing this mentioned on an episode of HPTV and doing a search here I didn't find much other then its either done by software or there may be a different valve body required to make it work. Does anyone know anymore about this illusive 6 speed 4L80E setup? I'm wanting to know how its done and what kind of gear ratios result from it. If its just software then thats just a matter of changing the shift routine is it not? Any info is greatly appeciated.
oldred95 is offline vBGarage Page   Reply With Quote
Old 08-05-2008, 08:32 PM   #2
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 6 speed 4L80E
It's a valve body change plus a custom chip and an on dash controller.
Standard gear ratios for the 4L80E are the same as a TH400 plus an overdrive.
2.48
1.48
1.00
0.75
The 6 speed conversion splits 2 gears with the overdrive to give
2.48
1.86
1.48
1.11
1.00
0.75
Because the valve body is computer controlled with electric solenoids, the valve body swap is not cheap. The 6 speed conversion was most popular with trucks since it allowed the engine rpms to stay in the sweet spot by only dropping half a gear. Using OD as an extra gear isn't a true 6 speed since the OD gear is always small and weak. The OD gear is never a performance gear because of this.
AlkyIROC is offline vBGarage Page   Reply With Quote
Old 08-05-2008, 09:02 PM   #3
Re: 6 speed 4L80E
Interesting. So overdrive in the 4L80E is really that weak huh? It was kind of my understanding it would split the load and put less strain on the internals but maybe not. Is there any place online that has more info on this? I would like to see some pics of this setup if at all possible.
Old 08-06-2008, 01:10 AM   #4
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 6 speed 4L80E
All overdrives are weak because it needs a small gear driving a big gear. Automatic transmission OD is no different. OD is not designed for power. The final OD is designed for high speed, low rpm highway operation to cruise at a much lower rpm to save fuel. Splitting the gears with an OD still needs a small gear driving a big gear. In an automotive transmission, you just won't get a big enough small gear to take any abuse.
In a highway tractor, it's a little different. It's common for a big truck to have an 18 speed transmission but it doesn't really have 18 gears. It's really just a 5 speed with a high and low range for 10 gears plus an OD that can split all the gears to give a total of 18 gear ratios. The OD gears are in the back of the transmission and are separate from the main gears. They use 2 countershafts to increase the load strength on the output shaft. the only time you need to split a gear is when you need to change the engine rpm one or two hundred rpm. Running empty, you can start in low gear and go through to high in only 10 gears or less, not needing the OD gears at all.
The 4L80E 6 speed conversion is the same thing. The split gears is only needed when in a truck as a tow vehicle and you need to drop down half a gear when climbing a hill to keep the engine in a slightly higher rpm range until the rpms drop down again for another 1/2 gear split. In a lighter vehicle, the extra gears are not required because it doesn't need as much HP to move the lighter vehicle. Climbing a hill, it's unlikely it won't even drop out of high gear. When I towed my car through the mountains years ago with my 454SS pickup which has a 4L80E, the transmission never dropped out of OD at all going up the mountains.
A proper 6 speed tranny would be more like the 6L80E with a very low first gear. It would give good acceleration off the line with something like 3.23 gears in the diff and have an OD for high gear on the highway.
Trouble with most 6 speeds transmissions is they're not really a 6 speed. The T56 has the gear ratios of a 4 speed tranny and has 2 OD gears. Unless you cruise down the highway a lot, you'll probably never use the OD gears.
Old 08-06-2008, 07:52 AM   #5
Re: 6 speed 4L80E
I see what you're saying. I thought it was odd that such a thing as a 6 speed 4L80E conversion kit existed yet nobody seems to know much about them and I've never known anybody that used one. My only beef with the 80E is the tall first gear ratio but that can be overcome with a high stall converter. Thanks for the information.
Old 08-08-2008, 10:38 PM   #6
Re: 6 speed 4L80E
You realise that the same 2 planet assemblies are used for both under drive one to one and over drive right?
Planet assemblies consist of the sun gear planet gears and the ring gear.
Depending on how torque is routed each assembly has 6 ratios. 4 forward and 2 reverse.
The only thing that varies is which element of the planet set is static which is input and which is output.
ls six is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Turbo Iroc - Round Four (Edit: Staying Gen1, new PT7675, heads, intake) ZZ3Astro Power Adders 217 11-03-2016 03:44 PM
[CA] 1989 Trans Am w/ just 32k miles for sale jrdturbo Firebirds for Sale 26 03-31-2016 03:58 PM
1991 Camaro Speedometer Board; Broken, now working! Elephantismo Electronics 12 11-14-2015 10:40 PM
Is it the Ignition Control Module...AGAIN?!? RedLeader289 Electronics 6 09-23-2015 07:50 AM
WTB 87-91 iroc/z28 5 speed FLAP Camaros Wanted 0 09-02-2015 10:22 AM
Go Back   Third Generation F-Body Message Boards >
Tags
2nd, 454, 4l80e, body, conversion, conversions, downshift, gear, low, overdrive, ratios, set, speed, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
