Need Help With 700R4 Valve Body Pressure Switches?
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
87 El Camino had a 2004R and a 305 with a 4bbl.
Now has a 350 TPI 90-92 speed density 1227730 with a 700R4.
The code for the 700R4 is 3Yp, NO Aux valve body, Type 1 valve body.
My question is do i replace the valve body pressure switches with the ones for a 3YP?
There are 2 pressure switches, according to the factory manual they should be Normally Closed.
From what can tell the 3YP is from a 1983 Monte of Caprice.
trying to get the lock-up to work properly so i can use the TPI to control it.
Any help would be great.
Thanks,
Dave drb930@gmail.com
Thanks,
1992 Trans Am
05-10-2023 07:19 PM
backtothe80s
09-05-2015 12:39 AM
TA8487
08-16-2015 12:21 PM
