Can't find replacement flywheel
Car: Red '89 GTA
Engine: TPI LB9
I need a new flywheel to my '89 Trans Am GTA. It has the LB9 (305 TPI) engine with borg warner T5 trans and is completely stock. On the old original flywheel it reads: 14088647N. But I can't find a flywheel with this specific part number. Does anyone know where I can get a fitting flywheel that can be shipped to Europe?
Would this f.ex. work?
http://www.1aauto.com/1A/Flywheel/Po...LF00012/592201
My car has VIN code F but part number doesn't match.
Re: Can't find replacement flywheel
The pn is good at GMPartsDirect as well (check the description there):
http://www.gmpartsdirect.com/results.cfm
JamesC
Car: Red '89 GTA
Engine: TPI LB9
Thank you JamesC!! I think maybe I will buy this flywheel then. But it is strange the part number on the original wheel can't be found...
