where to get the BEST clutchs/Band for 700R4?
ART CARR Has some, but they are high and they only like the stock amount, while others like to stack more(thinners ones) in the clutch pack. What about a Kevlar Band? ART doesn't like it others do. What works the best? Who offers a Good high Performance rebuild kit for it? I don't like TCI stuff or there shift kit. I am going to put a TRANS GO shift kit in it.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I've been intigued by what I've seen here: www.700raptor.com
I may be getting my tranny stuff from there in a few months.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Block is STILL in shop! (Waiting for my to buy the rods!)
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Working on:
145 MPH IROC Speedo
Get some raybestos blue clutches. i believe Jegs sells a kevlar kickdown band for 700's
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
We have found that the Borg Warner Hi-Energy clutches ($2.50 each) to be the best for the 3-4 clutch pack. We use 8 BW clutches along with .060 Kolene steels ($3.00 each)or non-Kolene steels ($1.60 each) depending upon application. In the 2-4 band application, we use the Borg Warner Hi-Energy band ($13.00 each). This band contains some Kevlar to resist heat, but has much more holding power. Do not use the Kevlar band. We have used these clutches & band successfully in many 10-11 second cars. The Trans-Go Performance Shift kit is the only way to go. If you have any questions please call me at 800 7763288 Mon-Sat 10-6 PST and I will be glad to answer any questions.
Glad Too Help!!!
Glad Too Help!!!
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
