wont shift
Old 11-29-2008, 03:19 AM
rock861261's Avatar
wont shift
ok guys 91 camaro 350 i have a real low idle so i thought maybe my maf connector was unplugged(its broken bought a new one but not here yet) i plugged it back in and my car runs up to 2000rpm then will jump to 3500 like its in neutral then shift only after 4000rpm then it will run all the way to redline in 2nd any ideas bad trans or can the maf do this
Old 11-29-2008, 10:20 AM
rock861261's Avatar
Re: wont shift
anyone?
Old 12-01-2008, 01:37 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: wont shift
I've seen maf unplugged on many camaros and corvettes only to find that when plugged in the car runs worse. Your transmission uses no electrical at all to make shifts up or down. A bad running engine that is stumbling or weak can wreak havoc on the shift points though. I would recommend getting the maf hooked up properly and engine running good before doing anything transmission related.
Late shifting and no upshifting 700r4's a lot of times have a stuck throttle valve not to be confused with the T.V. plunger. The plunger can be seen by removing the trans pan and pulling the t.v. cable. to get to the throttle valve the valve body has to be removed. Aftermarket company's sell a throttle valve that has a return spring so it doesn't get stuck so easy. Probably if it is stuck it is stuck for a reason-debris too excessive. Stuck governors or stripped out plastic gears on them could also be a cause, and can be accessed by removing the round cover on the drivers side. Note: you did hook up the cable again when you installed your aftermarket intake right? YOU NEVER KNOW I just had to ask because your description is so clear on the intake track being aftermarket and all. The T.V. cable needs to be hooked up at all times or you damage your trans.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
darwinprice
17
10-11-2015 11:51 PM
racereese
10-03-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
AmpleUnicorn88
09-24-2015 09:15 AM
Quick Reply: wont shift
