Resurfacing lightweight flywheel
I have a 91 z28 1LE and my machinist told me i had a special lightweight flywheel. The question is that i'm going on my second clutch and it needs to be resurfaced again. Is there a maximum amount of times the flywheel should be resurfaced before being replaced. Will my Centerforce dual friction clutch produce enough heat to warp the flywheel. The car now has 62,000 miles on it, so it's gone through at least 2 clutches already.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Car: 88 Firebird WS6
Yes, not really a maximum amount of times it could be machined, but more of a minimum thickness. If your last clutch was stingy on chewing the flywheel and your machinist last time JUST removed the minimum amount to clean it.... and it's not TOO bad now, maybe a competant guy could surface it within spec..
I don't know the spec off hand (min thickness) but usually it's a good idea to change the flywheel, especially for performance.
[This message has been edited by JoelOl75 (edited April 26, 2001).]
monte87cortez
09-26-2015 08:10 PM
