Which Posi units will fit in my 10 bolt ..
Has anyone tried the Power Traxx unit ??
Will a posi unit from another 10 bolt work ?? Or do I have to replace the whole rear end ??
Appreciate the help ... Thank's
1 Post
Car: 82 camaro SC
I've had the powertrax for over 4 years without any trouble. It is streetable. Any 10 bolt limited slip carrier will work. Eaton, Auburn, SLP, ect. The SLP torsen's are cheap if you have 28 spline axles and 3 series gears already. Auburns cost about what a powertrax will cost. Eatons tend to be a little weak. All of the limited slip differentials require the gears to be pulled and the carrier to be replaced. With the powertrax the gears and carrier stay in the differential. What do you want to do with your car?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
evilstuie
04-14-2016 08:52 PM
hectre13
08-26-2015 08:17 AM
