Thread pitch for Trans mount bolts? 700r4 / 4L60?
Does anyone know the thread pitch and size for the 2 bolts to bolt the mount to the transmission?
Anyone know the nut needed for a stock mount?
I find I can't find my old ones, and I have NO idea what they are. Can't exactly take the transmission into a shop and pick and pull till I find a bolt that fits.
I've read that the heads are 14mm, but I'm not sure about the thread pitch, though a 14mm head sounds right.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Thread pitch for Trans mount bolts? 700r4 / 4L60?
I thought every car guy had a Magic Bolt Box. It magically has every bolt known to man, except the one you need, And it magically changes it's contents according to what you need. I have a 5 gallon MBB. But here's a tip. If you can find a spare 700R-4, the bolts for the tailshaft housing should usually work for the mount. You might need some washers. These bolts usually take a 15 mm wrench or socket.
Car: 1985 Chevrolet Camaro IROC Z
Engine: LB9 305 Rebulit Original to the car
Axle/Gears: 3.42 RPO GU6
I have mine in hand out of an 85 IROC with the 700R4. M10 X 1.5 x 35mm in length.
These things should be as common as a wrench in every tool box.
http://www.threadtoolsupply.com/inch...d-checker.html
http://www.threadtoolsupply.com/screw-checker.html
http://www.threadtoolsupply.com/thread-pitch-gauge.html
Here is another option for measuring bolts and nuts that I have.
