REAREND GURUS PLEASE READ INSIDE!!!!
Old 08-22-2001, 07:15 PM
vortech305's Avatar
my friend is in the process of building a worked 355 motor, pushing 420hp at the crank, he using a th350 tranny w/a street fighter converter, my question is this, which rearend is the best choice for him, he has 2 as of now, choice #1 7 1/2 rearend 1- bolt 3:73 gear and posi unit or a 9 bolt from a trans am with a limited slip differential and a 3:73 gear from SLP, he has both and we need to know which is the best rearend to use...
Old 08-22-2001, 07:17 PM
vortech305's Avatar
damn 1st choice is a 10 bolt(misspelled)
Old 08-22-2001, 11:18 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt is stronger than the 10 bolt by far! It has 4 pinion (spider) gears and 2 side gears vs 2 & 2 in the 10 bolt. The 9 bolt has axle retaining flanges vs C clips. The 9 bolt can be serviced for longer life, the 10 bolt can't.
I now have parts available for 9 bolts (new carriers and gear sets, - other stuff is coming soon). They are not as cheap as 10 bolt stuff, but they are a lot cheaper (and lighter) than a 9 inch (or 12 bolt) and much stronger than a 7.5 (or 7.625) 10 bolt. I have been running a 9 bolt behind my big block (500hp 520lbft) for almost 3 years now with 1.72-1.75 60 ft times. So have other people. I can get ratios from 3.2x to 4.1x.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
[This message has been edited by 88 427 Camaro (edited August 22, 2001).]
Old 08-22-2001, 11:37 PM
R.O.B.'s Avatar
Vortech305,
Dude, I don't want to start a war or nothing, but what the hell does a rear end have to do with "Body & Interior"?
Old 08-23-2001, 06:32 AM
RCR
RCR's Avatar
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
moving post to transmissions drivetrain...
[This message has been edited by RCR (edited August 23, 2001).]
GTAman
03-15-2019 11:40 AM
GTAman
09-21-2015 09:57 AM
formula_novice
09-05-2015 03:58 AM
andy74
09-03-2015 08:41 AM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: REAREND GURUS PLEASE READ INSIDE!!!!
