86' Iroc Z28 posi????? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 05-12-2009, 10:11 PM   #1
Car: 86' Z-28 Iroc Camaro
Engine: V8 5.0
Transmission: Automatic
dose a 1986 Iroc z28 have a rear posi?? because when i rearly do burnouts i only see one line in the street. is there somthing i need to do or fix to make it 2 lines in the street?
nghanie is offline vBGarage Page   Reply With Quote
Old 05-12-2009, 11:23 PM   #2
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 86' Iroc Z28 posi?????
I think you're question is this, in 1986 did Iroc's come with a posi unit standard? I'm honestly not sure if they did or didn't. The easiest way to tell would be to pull the diff cover and look; if you see clutch packs on either side of the case than yes you have a posi, if not you don't. You could also check your rpo sheet, but its a very real possibility the origional rear was rebuilt or replaced along the line sometime. I suggest popping the cover off simply to change the gear lube if nothing else, it's probably been a long time since it was done. While you're in there you can figure out if you have a posi carrier and what gear ratio you are running as well. If you are only spinning one wheel chances are you have an open rear, if your only spinning 1 wheel but find a posi unit installed chances are the clutches are shot and it needs to be replaced or rebuilt. If you're not sure what you're looking at take some pictures once you pull the cover and post em up here and we can tell you what you have. So to answer your question you either need to rebuild your current posi unit if you in fact have one, or replace it with a new unit. While you're at it you could also swap to a better gear set since your auto car most likely came with 2.73's installed(if that's the case you would probably want to upgrade to a series 3 carrier, although you can get some thick 3 series gears that are made to work with a series 2 carrier). Also you posted this under the wrong subforum, mods may want to move to transmission and driveline.
89RsPower! is offline vBGarage Page   Reply With Quote
Old 05-12-2009, 11:33 PM   #3
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i believe some came with a ratio of 3.42 posi, and some came with 3.23
gurkgurkgurk is offline vBGarage Page   Reply With Quote
Old 05-19-2009, 07:54 PM   #4
allboutspeed's Avatar
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 posi
Quote:
No '86 IROC's with the auto option came with 3.23's. In '86 IROC auto's had either 2.73 or (if equiped with the "G92" RPO) 3.42. Out of the 49 something thousand produced there were 50 350 equiped IROCS and all coming with either TPI or CARB. If it is carb'd you are doomed with the 2.73 if it is TPI it could be 2.73 or 3.42. As stated you should pull the cover and verify if you have a posi that needs repair or if you are doomed to one wheel peels. Of course this is all assuming that you have the factory rear-end in there still.
allboutspeed is offline vBGarage Page   Reply With Quote
Old 05-20-2009, 12:52 AM   #5
Old 05-20-2009, 07:01 AM   #6
Car: 1987 Black IROC-Z (original owner)
Engine: 350 Crate with TPI
Transmission: 700R4 with 2400 SLP Stall
If it was a IROC-Z28 then it would have have the G80 limited slip rear option. Your problem is the car has had too many burnouts over its lifetime the the rear limited slip is history.
DJP87Z28 is offline vBGarage Page   Reply With Quote
Old 05-20-2009, 07:42 AM   #7
JamesC's Avatar
Car: Met. Silver 85 IROC
Transmission: T-5 (Non-WC)
Quote:
http://www.thirdgen.org/techboard/tr...-10-bolts.html
JamesC
JamesC is offline vBGarage Page   Reply With Quote
Old 05-20-2009, 07:52 AM   #8
big gear head's Avatar
The '86 could have had the Auburn or the Governor Lock. If it's the Auburn then it's worn out and needs to be replaced. If it's a Governor Lock then the gear on the governor may be broke, which will not allow it to lock up. Either way I recommend replacing it with a new Eaton Posi.
big gear head is offline vBGarage Page   Reply With Quote
Old 05-20-2009, 01:43 PM   #9
Quote:
That's a myth, nobodys ever been able to prove the existance of one.
Old 05-20-2009, 01:43 PM   #10
Quote:
Don't recall an f-body ever having a gov lock from the factory..
Old 05-21-2009, 01:23 PM   #11
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Yes they did. You have a GM 9 bolt Borg Warner BTR 78 7.75 inch ring gear with a cone type LSD. You can rebuild it or replace it with another diff like a Ford 9 inch. There is a German LSD clutch type that is very very expensive and totally not worth it that will fit. No one anywhere makes a Helical gear LSD for it. The GTO's will not work. If your IROC started out as a 305 you might have a 10 bolt. In which case you can get a Truetrac for it but the 10 inch is worthless and weak so I would swap it for a 9 inch best deal I have seen is Currie about $1300 bucks but you will have Ford rear discos.
mmadden55 is offline vBGarage Page   Reply With Quote
Old 05-21-2009, 05:21 PM   #12
Car: '87 IROC Z-28
Quote:
The 7.75 9 bolt didn't come in these cars until 1987. The 86 had the 7.625 10 bolt. Also, in 86 all IROC's had the 305 (some with the HO option) except for the "rumored" 50 that were equipped with the 350.
Old 05-21-2009, 06:28 PM   #13
Car: 86 Firebird
Engine: 305 SBC
I stand corrected in anycase toss the center and put a truetrac in there. The 10 bolt still won't be all that strong but you will have traction and cost is less the $ 500 for the part otherwise go to a 9 inch but that will cost you.
Old 05-22-2009, 07:13 PM   #14
I've seen several of the F bodys and SS Monte Carlos with the Governor Lock.
Old 05-23-2009, 06:09 PM   #15
same here, just never heard of one being installed from the factory in a f-body, not sure about the monte's though. Thought they only came in trucks..
Old 05-23-2009, 11:25 PM   #16
The 7.5 rear end is the only one that I have ever seen in a car that had the Gov Lock installed from the factory. I've never seen the 8.5 in a car with the Gov Lock from the factory. I think the 7.5 might have got the Gov Lock because of a shortage of the Auburn or a lack of something better to put in it.
Thread Thread Starter Forum Replies Last Post
86 T-top IROC-Z LSX Iron 408 LS3 Built t56 sell or trade as roller spohn bmr umi ambainb Camaros for Sale 11 04-25-2016 10:21 PM
Turbo on a budget: 91 Z28 rear mount build Orr89RocZ Power Adders 206 04-25-2016 09:28 AM
To paint or not to paint... neekolzun Body 32 08-24-2015 05:59 PM
1987 t-top for sale drewdock87 South Central 3 08-18-2015 10:02 PM
Making the non functional Hood air vents, into functional. mustangman65_79 Body 3 08-11-2015 04:17 PM
Go Back   Third Generation F-Body Message Boards >
Tags
410, 86, bypass, camaro, chevy, cost, engine, gears, governor, iroc, irocs, posi, rearend, rebuild, transmission, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
