Need help with my 700R4?
Old 07-05-2009, 11:05 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have a 91 RS with a 305 and 700r4 and it needs a rebuild which transmission should i get for it or is it easy to rebuild my self.
Old 07-05-2009, 11:29 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Need help with my 700R4?
i like the 700r4 but you will need a pro to help you do a rebuild, and lots of special tools.
Old 07-06-2009, 08:22 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I'm sorry, but that's just not the case. I rebuilt my first 700R4 with no prior experience rebuilding automatics and a bare minimum of special tools.
I would recommend getting a Pro-Built kit, as it has all of the parts you will need. Get an ATSG and/or Haynes GM Tranny manual. You will need a good pair of snap ring pliers (both internal and external), a clutch spring compressor (I got mine for about $40 at a swap meet), and a bushing/seal driver set. There are a lot of special tools spec'd in some of the manuals, but you can do without 99% of them. You can even use a feeler gauge as a lip seal tool (I did, with no problems). There are plenty of people here that can help you, and if you go with the Pro-Built kit Dana from Pro-Built will also be a great resource and help.
For years I thought that automatics contained some kind of alien technology that required all kinds of special training to learn how to fix. The truth is that they are just another mechanical part. You don't need to 100% understand how they work in order to rebuild them. You need to be dilligent, careful, and keep everything very, very clean, but if you can do that then you should be fine.
Old 07-06-2009, 01:47 PM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Sorry Tony, but I hafta agree with TKO on this one. Though I'd suggest getting the kit from TCI, and certainly don't get it from B&M.
Old 07-06-2009, 04:04 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
i took it to the shop and the mechanic told me it was gonna be $1500 but he was gonna build it like if it was for a corvette he said and. Also he told me that i have to take the car to him for the guarranty would cover the 100,000miles, or do you guys know anyone here who rebuilds transmissions or sells them.
Old 07-06-2009, 05:38 PM
Where are you located?
Old 07-06-2009, 10:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I live in Los Angeles county in California and i have seen this transmission on craiglist http://racetransmissions.com/store/p...roducts_id/195 for $1000. Also the guy said he has not installed it yet is that a good trans or should i buy one from a shop instead
Old 07-07-2009, 05:45 AM
If you're in California the only place you should buy a trans is ProBuilt. His site is www.700r4l60e.com and he's in Calamesa, CA. I used one of his kits when I rebuilt my 700R4 and the results are awesome. Dana is super knowledgable, and truthfully the only person I trust with a 700R4 other than myself. His kit is good to at least 575HP and he helped design a lot of the parts that are in the kit. His slightly modified version of the TransGo skift kit is superb. I can't say enough good stuff about Pro-Built.
Old 07-07-2009, 03:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Do you happen to know if he sells the transmission built already or they dont charge much to put that kit in my trans.
Old 07-07-2009, 09:31 PM
Check out this link: https://www.700r4l60e.com/store/home.php?cat=20
Pretty reasonable for a ready to go 700R4 if you ask me.
Old 07-07-2009, 10:10 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok i think i will get that one would you happen to know how expensive it would be to swap my 305 tbi into a 350tpi i have the engine already
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: Need help with my 700R4?
