1989 700R4 into 1993 9C1 Caprice
Old 10-30-2001, 02:06 PM
JeffP's Avatar
Curious about this swap. Does anyone know the following?
1. If the speedometer on the Caprice is cable driven or electronic? IF it is electronic, can the tailshaft be swapped out with the 1989 700R4 one? (The 89 tranny is a fresh rebuild, so would swapping the tailshaft from the dead 93 transmission hurt it in any way?)
2. Is the electrical connector on the side of the trans in a 1993 Caprice a 4 or 5 prong type?
Guess that's pretty much it. These are the only pitfalls of the swap I know of. Am I missing anything?
THANKS!!!
Old 10-31-2001, 07:27 AM
JeffP's Avatar
Any help is appreciated. Caprice needs to be driveable. Thanks.
Old 10-31-2001, 08:07 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
the 93 has to be electronic speedo for two reasons, #1, it's a 4L60E trans, and #2, the speedo on the dash is digital. I think they all went to electronic speedo by 91.
not sure about the other two questions really.
Old 10-31-2001, 11:34 AM
JeffP's Avatar
It's not an electronic transmission.
Old 10-31-2001, 11:39 AM
JeffP's Avatar
If the speedometer is electronic, can the tailshafts of the two trannies be swapped without any negative effects?
Old 11-01-2001, 05:24 PM
JeffP's Avatar
Does anyone have any correct information?
Old 11-01-2001, 09:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I went the other way, my Camaro has a 4L60 from a 93 Caprice 9C1. The TCC connector has 4 pins, not 5. I'm pretty sure the Caprice has an electronic speedo, but you wouldn't need to change the whole tailhousing, just the speedometer gear housing/VSS. I had to swap the tailhousing on mine anyway since the Caprice doesn't have a torque arm. You'll also need to swap the levers on the selector shaft.
wanext
10-06-2015 12:18 AM
loud91rs
10-05-2015 10:05 PM
indygene
09-26-2015 11:21 AM
Dragonsys
09-25-2015 03:51 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 1989 700R4 into 1993 9C1 Caprice
