T-56 clutch fork won't go on?!?!?!?
does anybody have any suggestions? i have the tranny bolted to the bellhousing, but the fork just won't go on the bearing. i tried turning the engine over to move the bearing to that flat spot, but it just doesn't seem to work. please help. i want to be able to drive my thirdgen again
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Sounds like you might have the wrong throwout bearing. The T5 bearing I had had no "flat spot", it was completely round. The T56 bearing is sort of square shaped...
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Shouldnt be able to have the wrong t/o bearing, the LT1 its part of the press plate... unless you tried to use a T5 clutch :-/ .....
the fork wont go on at all? can you get a picture of this? what exactly is it doing, besides not going on. i am not sure about this but i dont think the fork slides on all the way, i couldnt get it to reach all the way on mine when i "test" fitted my clutch,flywheel,PP.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://ScreaminDeamin.cz28.com
Brandon
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
The LT-1 T.O.B. is the one with the ROUND clutch fork engagement section, and the TOB can be removed from the PP by simply removing that retention spring. The LT-4 T.O.B. is the one with the SQUARE clutch fork retention section, and is retained in the PP in the same manner as the LT-1 TOB. I haven't used a LT-4 TOB in this application, but I have used LT-4 PP's with LT-1 TOB's all the time. You sure that you have the CLUTCH FORK engaged in the T-NUT properly? This shouldn't be causing such a problem unless something is actually wrong. The best bet is to just remove the gearbox again and check things out. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/Fully ported 1990 Corvette L-98 heads/AFR Hydra-rev/ T-56 6-Speed/ PRO-5.0 shifter/ 1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
wel i know that i haqve the throughout bearing that has a flat side. when i put the clutch in i made sure that the flat side was so that i could slide the fork on when the time came. well when the time came it wouldn't go on. it just seemed like there was no flat side where i thought. the bearing looked slightly too big. so i cranked the engine over a couple of times while checking in between to see if the flat side had turned to the right spot. but it never did. i guess i'm gonna just have to take the gearbox out again. exactly how should the retaining nut on the fork be? tighten it down all the way or what? thanks for your help guys
well i got my trans stabbed tonight, boy that sucked. my question is does the fork have to be completely on the TOB? here is a image to show what i mean.sort of.
that is how mine is right now it was as far as i could get it right then, so i gave up for the night and figured i'd ask if it would go further.
Brandon
[This message has been edited by ScreaminDeamin85Z (edited November 01, 2001).]
Brandon
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Ok I know whats wrong. I make sure I have it on before I have it completely stabbed. I when I had mine rebuilt the hicks couldnt get it on by force so they grinded the bellhousing some (so the fork can pull further out and you can get it on the bearing.)
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Car: 1991 Z28
Well I just had the tip of the input shaft in the pilot bearing and "snaped" the fork on the bearing and continued installing the trans. your fork is unable to pull out enough to get over the throw-out bearings lip right??
91 Z28 5.7l Camaro
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
by stabbed he means, tranny to bellhousing attached. i dont think that i can do it like this though, the fork doesnt appear to be long enough. also i dont want to pull the trans away considering how much of PITA it was to get stabbed to begin with.
Brandon
Brandon
Car: 1991 Z28
dont pull it completely away. the only way the people who installed my trans could attach it was by grinding some metal away from the bellhousing so they could pull the clutch fork away just alittle bit.
Car: 1991 Z28
That should be good if I remember correctly. The edges of the fork should in the middle.
[This message has been edited by Chris Etemadi (edited November 02, 2001).]
tonys91rs
10-10-2015 03:31 PM
mygta87
09-14-2015 10:36 PM
