driveshaft
1 Post
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
driveshaft
I just installed a th350 with a short tail shaft in my 82 Z, I am going to need a driveshaft and was wondering if anyone knew if I could use any GM car that had the same set-up and use that driveshaft. If the length is the only consideration then it should work...right? Thanks
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Re: driveshaft
You should be able to use the stock driveshaft if the car had the 3 speed th200 in it.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
topteam54
10-06-2015 12:21 AM
