what driveshaft options?
Car: 5 cars
i just ordered up a moser 9 inch housing and axle set up and wilwood drag brakes for my 84 t/a
700r4 trans
what do i have for options (or companies) as far as driveshaft goes?
700r4 trans
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: what driveshaft options?
The quick and easy method is to have your stock shaft shortened and balanced, and use a conversion-style u-joint.
But if you need a 9", you probably need to have a stronger shaft built. Every major city has at least one shop that can do this, or you can go with one of the famous shops, like Denny's Driveline or Inland Empire.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I bought a Spohn one for when I did my TH350 swap.
if your gonna have some serious power i bought mine from these guys http://www.dennysdriveshaft.com/
gixxer92
05-18-2017 11:20 AM
