trans won't shift after filter change...need help
Old 06-11-2010, 09:58 PM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
just wanted to change my filter and fluid in my 89 camaro auto 700R4 and now it won't shift into second gear just goes like 10 mph and won't shift..anything I didn't notice I could do when changing the filter out...it shifted somewhat hard before I started this lastnight,havent had any probs wit the trans...thanks for the help,this is my only ride at the moment.oh yea I forgot the filter o-ring on the old filter was still in and put the new filter wit oring also in together but done took off the pan and removed one of the orings...
Old 06-11-2010, 10:02 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: trans won't shift after filter change...need help
if you neglected your tranny by not changing the fluid ever ever... then you my friend have a boat anchor... on older tranny's there is a myth that if you don't take care of your tranny by doing a service on it regularly like clock work, then you should just continue your practice of neglecting it until it pops... you may have dislodged debris and clutch material with the new fresh detergents that are present in the fresh tranny fluid...
Old 06-11-2010, 10:03 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
oh yeah, you may want to check the governor for any wear...
Old 06-11-2010, 11:16 PM
umm nope I take care of my cars...only had te car for 6months..how hard is the governor to get too and what should I look for when looking at it..i only drovethe car a block or two...it takes off fine just won't go into second gear...
Old 06-11-2010, 11:47 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
yeah, well you've had it for 6 months... who knows what the previous owner's habits were like when it came to maintenance...
Old 06-12-2010, 12:03 AM
you for reals...you replyed to just say that...how was that gonna help me...
Old 06-12-2010, 12:18 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
lmao... the governor is located behind a big round cap on the drivers side of the tranny... what you need to look for is for a worn gear... some people have been able to take the cover off with the tranny in place, others have had to drop the cross member and lower the tranny a few inches ... some of the problems though that have been mentioned are having difficulty placing the cap back on and being able to set the governor in place... just things to keep in mind...
Old 06-12-2010, 01:00 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The general not so easily proven rule of thumb is, if the 700R4 has never had the trans fluid change and its beyond 75,000 miles, don't do it.
The mass amount of new fluid full of new detergents, scrubs the inside clean and clogs up stuff.
Now its not a proven fact, but a real Murphys law possibility.
Kinda like, after that many miles of neglect, just leave it alone if it still works.
Old 06-12-2010, 06:41 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Is the fluid level correct ?
Old 06-12-2010, 09:42 AM
I'm almost sure it is but when I get off I'm gonna check again and I guess jack it up and look around for the third time now...the first time I left the old o-ring still inside along wit new o-ring..took it for like 4 blocks and notice it was shifting right and taking to long so got home notice the o-ring wasn't on the old filter so jacked it right back up and redone everything and took the old one out...and now won't shift out of 1st gear only goes like 15mph...
Old 06-12-2010, 08:55 PM
I check the governor gear just now and no signs of wear at all on the gear it's self...but the two metal flaps on is side move freely easy...anything else I should look at on it while it's out...abt the easyest thing I have ever did on this car was take it out...so if the gear is good does this mean the trans is dead or ?....thanks alot for tthe help...
Old 06-13-2010, 06:15 AM
Anyone?.....governor gear is good what's next now buy another trans?....thanks
1992 Trans Am
05-10-2023 07:19 PM
camaro11j
09-19-2018 08:49 AM
maroe624
04-16-2017 08:29 AM
mizz0313
08-12-2015 06:45 AM
Quick Reply: trans won't shift after filter change...need help
