new torque converter trouble
Old 07-11-2010, 09:08 AM
sicktwin's Avatar
Car: 1991 Trans-Am,1990 Nissan 300zx TT
Engine: 5.7/350
Transmission: AUTO
Axle/Gears: 3:42
I just bought 2800 stall converter and done a 355 swap. went to take it for its first ride last night and when i put it in gear its starts making a grawling noise only in gear. from under the car it sounds like its coming from the converter but im not sure and of you experience this with a new aftermarket converter.
What makes these converters go bad and do this
Old 07-11-2010, 01:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: new torque converter trouble
Are you sure you got it all the way in?
It can fool you and feel like its in, when its not.
Always best to do it like 30 times in a row to make sure its all the way in.
If not, it can still bolt in but will just chew up the trans pump as its not engaged right.
Should sort of cluck in twice, when your puttin it in, it does it once, then ya twist n fiddle to get the TC notches to hook into the pump and it does it again.
Old 07-11-2010, 05:06 PM
sicktwin's Avatar
Engine: 5.7/350
Transmission: AUTO
Axle/Gears: 3:42
yeah it was all the way in i had done it several times to make sure. and it didnt do it right away. it almost feels like the converter is locking up like a 1 to1 ratio like it didnt even want to pull it self and this stuff is all new no idea why . Im so mad about it i can barley even look at the car.
Old 07-11-2010, 05:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
sometimes it help to park em for a while if ya got another car n let your mind resolve it as needed.
Old 07-11-2010, 07:30 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you DID service the new converter with fluid before you installed it ??? good luck .
88rscamar0
09-23-2015 09:08 PM
Nick McCardle
09-10-2015 08:36 PM
89fast5oh
09-08-2015 09:55 AM
Vassago
Convertibles
09-04-2015 09:37 PM
Quick Reply: new torque converter trouble
