700-R4 not shifting till 4,500 RPM
Old 08-07-2010, 09:53 PM
jon3003's Avatar
I'm a bit of a gear head but tend to stay away from transmissions. My transmission was rebuilt 2 years ago with a shift kit. Now it's having problems shifting into any gear without reving the **** out of my engine and it won't go into overdrive at all. I've messed with the throttle adjustment and there is no difference in the way it shifts. It's a 92 Camaro TBI any idea's?
Old 08-09-2010, 04:24 PM
chevy lovin's Avatar
Re: 700-R4 not shifting till 4,500 RPM
throttle valve inside the transmission is stuck. that what mine did.
Old 08-10-2010, 12:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
My 91 RS acted the same way when the little clip at the throttle end of the TV cable broke.
I never got over 3rd gear so I don't know if it would have shifted to 4th or not - but the engine had to reach the yellow line in 1 & 2 before it would shift and stayed like that until the broken TV cable was replaced.
Could be the cable, ( broken inside the sheath or inside the tranny ) or it could be the valve.
Old 09-10-2010, 07:40 PM
92 tcr car's Avatar
Hi all. Let me start by saying that I am new to this site and to the third gen camaro. I have a '92 RS w/ 305 TBI and TH 700 R4. The transmission works fine under normal driving conditions but under WOT it will not shift untill the tach has run off the numbers ( Im guessing about 7800 rpm). can anyone help? I have purchased a new governor but not yet installed it.
Old 09-10-2010, 08:19 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
If that happened you wouldnt have a motor left. I'm guessing your tach is fubar.
Old 09-10-2010, 08:28 PM
92 tcr car's Avatar
That is among the possiblities I have been looking at. The tach tells me Im at around 3100 rpm at 60 mph. This seems high comppaird to other OD cars I own.
Old 09-12-2010, 02:19 AM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Did you get a new clip or a whole new cable
What is the clip called i really need one
jklein337
09-19-2018 06:23 PM
someone972
08-30-2015 12:52 AM
Irocohio
08-12-2015 08:03 AM
dhonda200
08-11-2015 11:50 PM
Quick Reply: 700-R4 not shifting till 4,500 RPM
