Looking for an aluminum drive shaft for my 84 Camaro
Old 08-14-2010, 12:59 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Hello. I have a 1984 Camaro Berlinetta. It was a six cylinder, but I swapped it for a fresh 355 engine. Also a 5 speed standard transmission from a 86 trans am and posi rear end with 327 gears. Here's my problem, I have a vibration issue that comes on around 60 miles an hour and gets progressively worse as I speed up. I was reading here at third gen where a lot of guys have had this problem and it ended up being that the fix was replacing the steel drive shaft with an aluminum drive shaft. So I looked on Ebay but couldn't find any. Was hoping my pals here would have an idea where I can get one? I am from Ontario Canada so it would be great to find a place up here....so the shipping isn't such a killer.thanks
onthedownlow
Old 08-14-2010, 02:28 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Looking for an aluminum drive shaft for my 84 Camaro
An aluminum one from a 4th gen will fit perfectly.
Old 08-15-2010, 01:38 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Check ebay. They're on there all the time for around 75-125 usually
Just type in aluminum driveshaft or camaro driveshaft
Old 08-15-2010, 07:42 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
All 1LE aluminum 3rd gen & 1LE & 3"dia aluminum 4th gen from a Auto or Manual car will work for you.
Old 08-15-2010, 02:03 PM
Engine: 355
Cool, thanks for the quick response. I will look on ebay and see what I find. Thanks.
Old 09-03-2010, 12:22 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
if you still need one I have a spare sitting in my garage, PM me.
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
Reddeath210
10-06-2015 08:20 AM
jharrison5
08-19-2015 05:53 PM
Quick Reply: Looking for an aluminum drive shaft for my 84 Camaro
