Clutch help
Old 08-28-2010, 12:08 AM
Jusiah's Avatar
Clutch help
I replaced the clutch today, it still slips and it makes a horrible wrapping noise metal on metal almost...and its a steady noise when the car is running.. could we have installed the clutch disc backwards?
Old 08-28-2010, 08:52 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Clutch help
That or installed throwout bearing incorrectly. Remove trans and inspect.
Old 08-28-2010, 09:03 PM
Jusiah's Avatar
Re: Clutch help
The noise ended up being a piece of tin rubbing against the housing something like that my husband said...noise is fixed...however it still slips, I have been told the flywheel was not resurfaced enough....
Old 08-29-2010, 09:21 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: Clutch help
Take it out. Have the pressure plate and flywheel both machined (not scuffed) and if everything else is okay, the new clutch will work like one. It absolutely will not when using an unmachined flywheel.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Spyder_TheGamer
10-02-2015 12:25 PM
meeklay812
10-01-2015 03:46 PM
mfp189
09-27-2015 09:25 AM
Night rider327
09-02-2015 04:18 AM
Quick Reply: Clutch help
