Is the rear end in this craigslist ad a direct bolt in replacement for mine?
Old 01-31-2011, 06:50 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 383
Transmission: TH350
Axle/Gears: 4.11
I have an 88 base model. Would this rear end be a direct fit?
http://spokane.craigslist.org/pts/2187707449.html
Old 01-31-2011, 07:06 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Is the rear end in this craigslist ad a direct bolt in replacement for mine?
Sure will! Looks to be in good shape too.
Old 01-31-2011, 07:07 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 383
Transmission: TH350
Axle/Gears: 4.11
Nice. Now, I've never done a drum to disc swap before. What parts will I need other than what comes with that rear end in the picture?
Old 01-31-2011, 07:32 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
You will need a disk/disk proportioning valve otherwise you will be locking up the rear brakes at every stop. That or you can do the adjustable proportioning valve mod but that takes a bit more work.
Old 01-31-2011, 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
$400 seems steep to me. Isn't there an issue with getting parts, etc. to fix a 9 bolt once it craps out? I see 4th gen rears with LS1 brakes and better gears go for $150 less all the time - granted stock wheels stick out a tad, but that seller doesn't have to know that's an issue for you. I'd mention the ill-fate of repairing a 9 bolt, and the cheap price of a 4th gen rear, and see if he'd take half that!
Old 01-31-2011, 09:47 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
Bit high! They go for $200 to $250 in the Chicago area..
Old 02-01-2011, 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Regardless of the disc rear you chose, you'll need a combination valve, parking brake cables, and most likely the correct drive and/or driven gears to make the speedo read correctly. Though the following link is a 10-Bolt FAQ, the section on brakes will be the same for a 9-bolt:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
AkDrifted
08-17-2015 07:45 PM
mizz0313
08-12-2015 06:45 AM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: Is the rear end in this craigslist ad a direct bolt in replacement for mine?
