1991 Camaro V6 RS Rear Transmission Mount
Car: 1991 V6 Camaro R/S M
Just bought a 1991 Camaro V6 RS Automatic, the rear transmission mount is broken. The stick bobs up and down in the consul. Guy said it wasnt a huge deal but I beg to differ, the transmission is moving as the car goes over bumps? Yeah not going to fly with me. I would like to know what mount is needed for this car. Again 1991 Camaro V6 RS Automatic trans. They guy said the original part is a liquid filled mount and it costs around $300 some for the part. I have been looking around and some mounts go for $60. I would like to know if there is an alternate, maybe performance mount that will work just the same. I think for the exact same part from another Camaro is what would cost $300. So if anyone knows about this issue please message me or comment on this post or how ever this website works.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1991 Camaro V6 RS Rear Transmission Mount
http://shop.advanceautoparts.com/web...zoneAssigned=1
$10 at Advance - simple rubber mount for the front.
You can replace with a polyurathane mount, but you get more vibration with a poly mount:
http://www.summitracing.com/parts/PTP-7-1604/
I'd use standard rubber Advance auto mount on a V6 car - takes 20 minutes to change.
If it's the crossmember, best bet is to grab a JY part. But you can get aftermarket like:
http://www.umiperformance.com/catalo...18bem5nf0anfc1
Car: 1992 RS
Engine: Carbed 350
And welcome to TGO! The feature works really well here - and everything you need to know about your car is in this board - just search, and if you can't find, then ask, we're glad to help.
Thank you so much. I knew that it couldnt be as complicated as he said it was going to be. I think he was more trying to find the original piece out of another Camaro.
I just order the OE polymount. are you suggesting the idea that I need to replace the support beam as well? or is the polymount interchangeable with the original ****ery down there?
Hotrodboba400
12-10-2019 07:07 PM
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
