Rear axle swap
Old 05-08-2011, 04:13 PM
Murraydpsr90's Avatar
Car: 1990 camaro rs
Engine: 5.0
Rear axle swap
I think it will but just to double check will a rear from an 88 iroc z (drum posi) bolt up to a 90 camaro rs
Old 05-08-2011, 04:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear axle swap
Yes. More swap info that you should consider below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old 05-08-2011, 04:38 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Ok the rear is said to be posi drum with 2.73 gears from an iroc z would it be a good idea to change the gears
Old 05-08-2011, 04:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Rear axle swap
For the cost to change the gears, you could just get a rear with the gears you want.
Old 05-08-2011, 04:44 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Well easier said then done I've looked everywhere been looking for a posi disc off a 90 to 92 but no luck
Old 05-08-2011, 04:47 PM
JamesC's Avatar
Re: Rear axle swap
Perhaps because of current prices in gasoline, you might consider highway gears like the 2.73's, but personally, I wouldn't want anything less than 3.23's. As Camaronebie mentions, find a rear with the gears (and brakes) you want. Remember too that there is the fourthgen option.
JamesC
Old 05-08-2011, 04:51 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
Same here as far as 3.23 but I don't care about gas prices just want what I want but can't find it
Old 05-08-2011, 05:02 PM
JamesC's Avatar
Re: Rear axle swap
Yeah, I understand that. If you haven't already, you might get aggressive and post in our site's classifieds and craigslist, call/visit boneyards or swap meets. I saw an 89 IROC roller with rear discs and PBR's just yesterday at Lawrence's swap meet, so they are out there. Good luck with the hunt.
BTW, what's under your 92 now?
JamesC
Old 05-08-2011, 05:18 PM
Car: 1990 camaro rs
Engine: 5.0
Re: Rear axle swap
It's a 90rs drum non posi sorry I didn't specify I just posted in parts wanted im always on craigslist and nothing coming up in and around new york
Old 05-08-2011, 08:56 PM
mchooks1234's Avatar
Car: 1987 Iroc Z28
Engine: 5.7L 350 Carburated
Axle/Gears: 3.27 9bolt
Re: Rear axle swap
I just bought a 9 bolt posi with 373 gears for my 87 IROC. I was a little weary of going with a 9 bolt considering I have a 10 bolt 273. But its the ratio I want and all I have to do is swap. So Im going for it! The question is, the new rear (9 bolt) has drum brakes. Has anyone ever seen this on a borg warner? Im not too concerned because I have drum now, but is there any things I sould look for or pay special attention to when doing the swap? Any advice would be helpful
Old 05-09-2011, 06:57 AM
JamesC's Avatar
Re: Rear axle swap
Since 3.73 is a 10-bolt gearing, are you sure it's a 9-bolt? IIRC, some early model cars were equipped with 9-bolts and drums. Further 9-bolt info here:
https://www.thirdgen.org/forums/faq-...now-about.html
JamesC
Old 05-09-2011, 09:29 PM
Car: 1987 Iroc Z28
Re: Rear axle swap
Upon further expection today I discoverd the rear I actually have bought has a 3.27 gear ratio. Im still going to install it and see how the car reacts. Im hoping for some improvement. As I understand it, this rear has a 3 series carier which means I can go lower on the ring and pinion gearing. Im happy to know some of them had drums and not a conversion I was worried about that. Is that 150 dollar ta cover worth the money? I cant seem to find a chrome one.
Old 06-04-2011, 01:56 AM
Z28Smitty's Avatar
Car: 1992 Camaro Z28 Z03 Vert
Engine: 5.7L Vortec TPI
Axle/Gears: 3.23 Posi
Re: Rear axle swap
I just picked up a 10 bolt 3.23 posi w/ disc brakes out of a 90 IrocZ off Craigslist for $200 delivered. The car was in a front end accident and had less the 100k miles.
I plan to rebuild the brakes, replace the wheel bearings, clean it up, paint it and install it next winter when I rebuild the rear suspension.
I was hoping to find one with 3.42 gears but couldn't pass on the price.
Old 06-28-2011, 10:52 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Rear axle swap
Will a 9 bolt that had disc brakes allow drum brakes to be installed?
I am looking to get a sweet deal on a 3.27 9bolt to replace the 2.73 10bolt in my car right now. The 9bolt has had the discs removed, and i'm fine with using drum brakes.
Old 06-28-2011, 02:37 PM
JamesC's Avatar
Re: Rear axle swap
No. The axle flange is different.
JamesC
customblackbird
08-15-2021 10:16 PM
ZMWojnar
Brakes
05-12-2019 10:43 PM
draco
10-04-2015 09:25 PM
E Rod
08-28-2015 05:17 AM
red90IROCls1
08-25-2015 06:56 AM
Quick Reply: Rear axle swap
