t5 leak?
Old 06-08-2011, 07:23 PM
IROCZdude's Avatar
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
t5 leak?
ok so i have a leak, this leak looks to be inside the bellhousing? is there a seal or plug that could be possibly leaking inside the bellhousing? i took of the plastic cover for the bellhousing and at first i thought it was a rear main but its dripping right at the bottom of the bellhousing. rear main is dry
Old 06-08-2011, 07:55 PM
Received 1,664 Likes on 1,262 Posts
Re: t5 leak?
No plug.
Most likely, it's your case being stretched; the usual cause of terminal T-5 death.
Here's pics of both designs of cases.
The countergear bearing is the smaller round thing in the front of each case, partially obscured by the clutch gear bearing retainer. When the case stretches, as a result of excesive torque being applied to it, the hole elongates, and the bearing no longer fits tightly. The leak is the symptom of this.
Once that has happened, the transmission is garbage. The gears are no longer held in the correct orientation to each other and won't last long. In fact, if your trans whines more than it used to in all gears except 4th, that's why.
Note in the pic, the dark stain below that bearing in the upper pic. That's a 1st design one. The stain is old gear lube. That one is trash. Just one of ..... many, too many I'd say .... in my retired no-longer-rebuildable core heap.
Time to start looking for a T-56.
Old 06-08-2011, 08:38 PM
IROCZdude's Avatar
Car: 88' Z
Re: t5 leak?
i knew this day would come, i should have been a little smarter when i put my 400 hp motor in and kept the stock tranny, its not like i have the lack of knowledge bc i knew it wouldnt hold long but its just my lack of income.
thanks for the reply tho it really helped alot.
RS Reaper
10-17-2018 07:52 PM
Mark_ZZ3
05-24-2018 01:02 PM
Reid Fleming
10-10-2015 09:56 PM
aaron7
09-30-2015 09:15 AM
mfp189
09-27-2015 09:25 AM
Quick Reply: t5 leak?
